get_tris_x like set_tris_x
hayri
PostPosted: Sun Jan 23, 2005 4:01 pm     Reply with quote
are there any function get_tris_a like set_tris_a.
or how to read tris registers using ccs way (without declaring tris registers) ?
Try this
PostPosted: Sun Jan 23, 2005 5:30 pm     Reply with quote
Can't think why you have a problem with doing this...
#byte TRIS_C = 0XF94
Then whenyou need to read the (in this case tris_c)
val = TRIS_C;
Haplo
Re: Try this
PostPosted: Sun Jan 23, 2005 6:48 pm     Reply with quote
Keep in mind this address changes based on the PIC you are using.
hayri
PostPosted: Mon Jan 24, 2005 2:05 pm     Reply with quote
why i'm asking for this!
HAPLO gives the reason above!!!
"Keep in mind this address changes based on the PIC you are using."
it may be helpful if you are working on a driver source code...
doesn't matter. it's not important.
Mark
PostPosted: Mon Jan 24, 2005 2:23 pm     Reply with quote
That is why you put device specific information in a device header file!
PostPosted: Mon Jan 24, 2005 2:28 pm     Reply with quote
You can fix that problem by testing for the type of compiler,
and then using the appropriate address. This assumes that
all the PICs that you're using (for a compiler type) have the
same register address.
#include <16F877.H>
#use delay(clock = 4000000)
#IFDEF __PCH__
#byte TRISC = 0XF94
#ENDIF
#IFDEF __PCM__
#byte TRISC = 0x87
#ENDIF
char c;
c = TRISC;
