Nick Guest
using port A4 as digital output. |
Posted: Fri Jan 21, 2005 11:49 am |
I have one analog port setup A0 and I'm trying to using A4 as digital output. Is there anything that I have to do special to make it a digital output?
Thanks,
Nick |
Mark
Posted: Fri Jan 21, 2005 12:45 pm |
You don't specify what PIC you are using, but RA4 on most pics can only sink current. It is an open drain pin. That means that it cannot output a voltage but can pull the voltage to 0 volts. If you want to use it as an output, then you will have to add a pullup to 5V through a resistor. |
rwyoung
Posted: Fri Jan 21, 2005 1:13 pm |
Nick -
Google for "open drain" and also consult the data sheet for the PIC you are using. _________________ Rob Young
Nick Guest
Posted: Fri Jan 21, 2005 7:05 pm |
yall are correct, thanks guys!
Nick |
