		| Author | Message |
		| Cheick Guest
				| Rs232 |
				|  Posted: Thu Jan 20, 2005 8:01 am |   |
				| Hi,
 I try to make a connection pic PC to post the character on the PC but that does not work.  Is what my code is false?
 Thanks.
 #include <18f452.h>
 #fuses NOWDT, NOLVP, PUT, NODEBUG, HS
 #use delay (clock=20000000)
 #use rs232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7,PARITY=N,BITS=8,STREAM=COM_1)
 char c;
 fprintf(COM_1,"\rOK!\r\n");
 fprintf(COM_1,"lire! ;-)\r\n");
 if(kbhit())
 c=fgetc(COM_1);
 fprintf(COM_1,"PIC a recu les charactere :'%c'\r\n",c);
 fprintf(COM_1," ASCII code %d decimal ou 0x%02X hex\r\n",c,c);
		| SherpaDoug
				|  Posted: Thu Jan 20, 2005 8:38 am |   |
				| What does your code do wrong?  Does it print anything?  You may have a problem with kbhit not referring to the stream, try:
 if(kbhit(COM_1))
 Also tell us what compiler version number you have.
 English grammar correction:
 "Is what my code is false?" should probably be "Where is my code wrong?".
 The search for better is endless.  Instead simply find very good and get the job done.
		| rwyoung
				|  Posted: Thu Jan 20, 2005 9:43 am |   |
				| In addition to SherpaDoug's question, what are you using for your RS232 to TTL level shifting?
 Assuming a MAX232 type chip, is it wired correctly?
 Are the voltages on its V+, V- pins correct?
 If you aren't using a level shifting chip and just driving the PCs RS232 port then you need to add the INVERT statement to your #use RS232 command.
 Another quick suggestion, use the "CODE" button when submitting code on the forum.  It keeps your formating rather than left justifying all the lines which makes it a bit hard to read.  Click "CODE" then copy your code into the text box and click "CODE" a second time.  You should see something like  bracketting your code.
 Rob Young
 | You cannot post new topics in this forum You cannot reply to topics in this forum
