Which PIC recomended has 3 PWM outputs and runs at 40 MHz?
kkobraa
PostPosted: Wed Jan 19, 2005 1:16 pm     Reply with quote
I've tried to search for a PIC controller that can handle 3 PWM outputs and can runs at 40 MHz. I need it for controlling 3 individual digital control BUCK converters, so that's why I need the clock speed of 40 MHz. The important thing is this PIC need to be cheap. I saw some 18F4x20 but it seems too expensive. I can't use timers because I plan to use them for other applications. If anyone has a better idea, that would be great. Thanks in advance.
Ken.
SherpaDoug
PostPosted: Wed Jan 19, 2005 1:38 pm     Reply with quote
Consider using 3 or 4 really cheap PICs running slower. I find it takes less time to write code and the product ends up more robust when I use a seperate PIC for each major function.
rwyoung
PostPosted: Wed Jan 19, 2005 1:44 pm     Reply with quote
Off the top, in the 16F family (20MHz maximum however) the PIC16F7x7 parts might work. Some have 3 CCP pins.
In the 18F (40MHz) the PIC18F6310, 6410 and 8410 all claim to have at least 3 CCP pins.
Another alternative would be to use 3 much smaller parts and have them work cooporatively.
Rob Young
PostPosted: Wed Jan 19, 2005 4:37 pm     Reply with quote
Jerry I
PostPosted: Wed Jan 19, 2005 6:04 pm     Reply with quote
I have used the 16F767 and it worked great for me.
It is limited to 20M, but how high do you need your PWM Frequency to be.
I am running a 10M crystal and am getting approx. 38.5Khz at 8 bit resolution.
Very Happy
