Is anybody know that is there any PIC model which gives 1MHz PWM signal?
Mark
Posted: Thu Jan 13, 2005 8:48 am
None at your 4MHz clock rate. Like I said, you need to run faster. If you run at 20MHz then you will get one but the resolution of the dutycycle will be low.
