input_b error, this dont read 0x00 from all port bits
Freesat
PostPosted: Wed Jan 12, 2005 8:55 pm     Reply with quote
hi..
i need read from port b or portd the value of byte ( reading parallel port ) and also send it from rs232 tx and rx on portc
using input_d() i can read value of byte, but if this value is 0x00 input_d() dont return value.
i need your help to solve this..
#int_ext
void ext_isr() {
Uart_ByteSend( input_d() );
function uart_bytesend only send it to i/o buffer register
rs-232 is work fine
if i send Uart_ByteSend( 0x00 ) the byte is send correct.
Mark
PostPosted: Wed Jan 12, 2005 9:45 pm     Reply with quote
Then what does it return? Are you saying that it just hangs? I think not.
PostPosted: Thu Jan 13, 2005 12:13 am     Reply with quote
You need to post the PIC that you're using and the compiler version.
Then we can look at the generated code.
