CCS And MPLAB V7
philippeM
CCS And MPLAB V7
PostPosted: Thu Jan 13, 2005 3:11 am     Reply with quote
How to kill the error message from mplab at the end of compilation :
Skipping link step. Not all sources built successfully.
BUILD FAILED: Thu Jan 13 10:10:12 2005.
regards
PhilippeM
PostPosted: Thu Jan 13, 2005 3:19 am     Reply with quote
CCS has no linker, so your error message suggests that you have chosen the wrong compiler settings.
Make sure that in "Project/Select Language Toolsuite..." you selected "CCS C Compiler for PIC12/14/16/18", the default "CCS C compiler" setting won't work.
If the above mentioned option is not available, then make sure you installed the CCS MPLAB plugin (downloadable from the CCS website).
PhilippeM
PostPosted: Thu Jan 13, 2005 4:55 am     Reply with quote
OK Now it's good : i didn't see that.
Thnaks a lot
Bests regards
PhilippeM
