#inline
alexz
#inline
PostPosted: Thu Jan 13, 2005 4:21 am     Reply with quote
I am using PIC16F877A, compiler version 3.190
When I use the "#inline" as follows:
#inline
void TxPacket(BYTE *Descriptor)
I get the error: Function definition different from previous definition
The function delared as: void TxPacket(BYTE *Descriptor);
Any ideas?
Alex
Re: #inline
PostPosted: Thu Jan 13, 2005 4:24 am     Reply with quote
#inline
Any ideas?
You need to add #inline to the definition as well.
alexz
Re: #inline
PostPosted: Thu Jan 13, 2005 4:26 am     Reply with quote
#inline
Any ideas?
Which definition?
Where I declare the function you mean?
Alex
alexz
PostPosted: Thu Jan 13, 2005 4:28 am     Reply with quote
If I add the #inline to the function declaration as well:
#inline
I get the following error:
Out of ROM, A segment or the program is too large
Alex
alexz
PostPosted: Thu Jan 13, 2005 4:48 am     Reply with quote
Right, I have solved it, I just had too large function.
I have splited it to a few smaller, and no problems then.
The next question is, can I use #inline only for functions, or I can use it for a separete row only as well?
What else does it effect except the speed?
Alex
Mark
PostPosted: Thu Jan 13, 2005 6:50 am     Reply with quote
It is for functions. Not sure what you mean by "row" unless you mean line of code which is of course "inline".
Tells the compiler that the function immediately following the directive is to be implemented INLINE. This will cause a duplicate copy of the code to be placed everywhere the function is called. This is useful to save stack space and to increase speed. Without this directive the compiler will decide when it is best to make procedures INLINE.
