treitmey
LCD DMC50448 samsung S6A0069X01 |
Posted: Thu Jan 20, 2005 3:15 pm |
//// LCD-DMC50448.c www.apollodisplays.com ////
//// Driver for common LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
#define set_tris_lcd_default() set_tris_d(0xff);set_tris_e(0);lcd.rs=0;lcd.rw=0
#define set_tris_lcd_r() set_tris_d(0xff);set_tris_e(0)
#define set_tris_lcd_w() set_tris_d(0x00);set_tris_e(0)
#define d_cycle 250
#define lcd_line_1 0x00 //address of the first line
#define lcd_line_2 0x40 //address of the second line
//#define lcd_line_3 0x10
//#define lcd_line_4 0x50
////////////////////commands///////////////////
const int8 clr_display = 0x01; //
const int8 return_home = 0x02; //
const int8 fctn_set = 0x20; //send this OR'd with one of the below
const int8 bus_8bit = 0x10; // Data length 8bit/4bit
const int8 bus_4bit = 0x00; // Data length 8bit/4bit
const int8 two_lines = 0x08; // one or two line display
const int8 one_line = 0x00; // one or two line display
const int8 font2 = 0x04; // font to use both look the same??
const int8 font1 = 0x00; // font to use both look the same??
const int8 entry_mode = 0x04; //send this OR'd with one of the below
const int8 pointer_incr= 0x02; // increment the address
const int8 display_shift=0x01; // shift the display
const int8 pointer_decr= 0x00; // decrement the address
const int8 display_ctrl= 0x08; //send this OR'd with one of the below
const int8 ON = 0x04; // display is on
const int8 cursor = 0x02; // cursor is on
const int8 blink = 0x01; // blink is on
const int8 OFF = 0x00; // display is off
struct lcd_pin_map
int8 data;//data bus
BOOLEAN rs; //command/data_bar sometimes refered to as rs..register select
BOOLEAN rw; //read/write_bar
BOOLEAN enable;//chip enable
} lcd;
#BYTE lcd = 8 // This puts the entire structure on D and E
#BIT lcd_busy=0x08.7 //7th bit of data bus
int8 lcd_delay=50;
int8 lcd_wait(void)
int8 n;
set_tris_lcd_r();
lcd.rs=0;
lcd.rw=1;//read/write_bar
lcd.enable=1;
while(lcd_busy);//wait in loop for busy flag to clear
n=lcd.data;
lcd.enable=0;
set_tris_lcd_default();
return(n); //returns address pointer
void lcd_write_byte(BOOLEAN rs, BYTE n)//rs=0=command dc=1=data
lcd_wait();
set_tris_lcd_w();
lcd.rs=rs;
lcd.rw=0;//read/write_bar
lcd.data=n;
delay_us(1);
lcd.enable=1;
delay_us(2);
lcd.enable=0;
void lcd_init()
delay_ms(15);//delay the required 15mS
set_tris_lcd_w();
lcd.enable=0;
lcd.rs=0;//rs=0=Instruction register
lcd.rw=0;//rw=0=write
lcd.data=fctn_set|bus_8bit;
lcd.enable=1;
delay_ms(5);//delay the required 4.1mS
lcd.enable=0;
delay_us(lcd_delay);
lcd.enable=1;
delay_us(100);//delay the required 100uS
lcd.enable=0;
lcd.enable=1;
// From here on we can listen to lcd_busy signal//
//lcd_write_byte(data/instruction_bar,byte_of_data);
lcd_write_byte(0,fctn_set|bus_8bit|two_lines);//(fctn set) 8bit/4bit,# lines,font
lcd_write_byte(0,display_ctrl|OFF|cursor|blink);//(display ctrl),ON,cursor,blink
lcd_write_byte(0,clr_display);
lcd_write_byte(0,entry_mode|pointer_incr);
lcd_write_byte(0,display_ctrl|ON|cursor|blink);//(display ctrl),ON,cursor,blink
//read_byte not finished,.. but should be easy enough,, same type of shift
BYTE lcd_read_byte()
int temp;
lcd_wait();
set_tris_lcd_r();
lcd.rs=0;
lcd.rw=1;
delay_cycles(d_cycle);
lcd.enable=1;
temp=lcd.data;
lcd.enable=0;
lcd.rw=0;
set_tris_lcd_w();
return(temp);
void lcd_putc(char c)
if(c<20 || (c>0x7F && c<0xA0)) return;
switch (c) {
// case '\f' : lcd_write_byte(0,1);
// lcdline=1;
// delay_ms(2);
// break;
// case '\n' : lcd_gotoxy(1,++lcdline); break;
// case '\b' : lcd_write_byte(0,0x10); break;
default : lcd_write_byte(1,c); break;
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE address;
switch (y) {
case 1: address=lcd_line_1; break;
case 2: address=lcd_line_2; break;
// case 3: address=lcd_line_3; break;
// case 4: address=lcd_line_4; break;
default: address=lcd_line_1; break;
address+=x-1;
lcd_write_byte(0,0x80|address);
#include <16f877.h>
#device *=16
#include <string.h> //FOR MEMCMP
#case
#use delay(clock=16000000,restart_wdt)
#fuses hs,nowdt,noprotect,nolvp//we have a wdt now
#define VER_MAJOR 1
#define VER_MINOR 02
#use rs232(baud=19200,xmit=PIN_C0,rcv=PIN_C1,invert,stream=DEBUG,errors)
#zero_ram
#include "LCD-DMC50448.c"
//======================= MAIN ============================//
int8 i=0x0;
//--------- START -------//
// fprintf(DEBUG,".");
fprintf(DEBUG,"STARTING U11\n\r");
fprintf(DEBUG,"FIRMWARE VERSION %u.%02u\n\r",VER_MAJOR,VER_MINOR);
setup_adc_ports(NO_ANALOGS);
set_tris_a(0x00);
set_tris_b(0x00);
set_tris_c(0x00);
set_tris_d(0x00);
set_tris_e(0x0);
lcd_init();
lcd_gotoxy(3,1);
printf(lcd_putc,"Hi");
lcd_gotoxy(2,2);
printf(lcd_putc,"dude");
// i++;
// printf(lcd_putc,"%c",i);
// delay_ms(1);
// if(!kbhit())
// i=fgetc(DEBUG);
treitmey
4 bit mode |
Posted: Thu Jan 20, 2005 4:58 pm |
//// 4 bit mode ////
#define d_cycle 250
struct lcd_pin_map
int junk:4;//data bus
int data:4;//data bus
} lcd;
int8 lcd_delay=50;
int8 lcd_wait(void)
int8 n;
set_tris_lcd_r();
lcd.rs=0;
lcd.enable=1;
n=lcd.data;
lcd.enable=0;
return(n);
fprintf(DEBUG,".");
lcd_wait();
set_tris_lcd_w();
lcd.rs=rs;
lcd.data=n>>4;
delay_us(1);
lcd.enable=1;
delay_us(2);
lcd.enable=0;
delay_us(2);
lcd.data=n;
delay_us(1);
lcd.enable=1;
delay_us(2);
lcd.enable=0;
fprintf(DEBUG,".");
void lcd_init()
set_tris_lcd_w();
lcd.enable=0;
//lcd.data=(fctn_set|bus_8bit)>>4;
fprintf(DEBUG,"1");
lcd.data=0b0011;
lcd.enable=1;
lcd.enable=0;
fprintf(DEBUG,"2");
lcd.data=0b0011;
lcd.enable=1;
delay_us(100);
lcd.enable=0;
fprintf(DEBUG,"3");
lcd.data=0b0011;
lcd.enable=1;
delay_us(100);
lcd.enable=0;
fprintf(DEBUG,"4");
lcd.data=0b0010;
lcd.enable=1;
delay_us(100);
lcd.enable=0;
// //lcd.data=(fctn_set|bus_8bit)>>4;
// lcd.data=0b0010;
// lcd.enable=1;
// delay_us(100);//delay the required 100uS
// lcd.enable=0;
//fprintf(DEBUG,"3");
// lcd.data=(fctn_set|bus_8bit)>>4;
// lcd.enable=1;
// // From here on we can listen to lcd_busy signal//
// //lcd_write_byte(data/instruction_bar,byte_of_data);
//fprintf(DEBUG,"4");
lcd_write_byte(0,fctn_set|bus_4bit|two_lines);//(fctn set) 8bit/4bit,# lines,font
fprintf(DEBUG,"5");
int temp;
lcd_wait();
set_tris_lcd_r();
lcd.rs=0;
lcd.rw=1;
lcd.enable=1;
temp=lcd.data;
lcd.enable=0;
lcd.rw=0;
set_tris_lcd_w();
return(temp);
switch (c) {
// lcdline=1;
// delay_ms(2);
// break;
BYTE address;
switch (y) {
address+=x-1;
#include <16f877.h>
#device *=16
#case
#define VER_MAJOR 1
#use rs232(baud=19200,xmit=PIN_C0,rcv=PIN_C1,invert,stream=DEBUG)
#zero_ram
set_tris_a(0);set_tris_b(0);set_tris_c(0);set_tris_d(0);set_tris_e(0);
lcd_init();
printf(lcd_putc,"Hi baby");
