How to check how long code takes to run?
jseidmann
PostPosted: Fri Jan 07, 2005 4:25 pm     Reply with quote
Hi, I wanted to know what ways there are to find out how long a section of code will take to run. I have an EEPROM connected and can store that time value in it to access later on. Is there a command that can store the time delayed between two points? What means have all of you used to see how long your code takes to execute some portion?
Jon
NikkiC
PostPosted: Fri Jan 07, 2005 5:25 pm     Reply with quote
Three ways: using an oscilloscope, using the simulator in MPLAB or simply counting the number of clock cycles required to execute any chunk of code.
Nikki
PostPosted: Fri Jan 07, 2005 5:28 pm     Reply with quote
See this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=20463
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Sat Jan 08, 2005 10:49 pm     Reply with quote
Set up a timer interrupt. Count the interrupts in the ISR. Sample the counter before and after the code of interest executes (assumption: code of interest is not inside another ISR). Calculate the difference of the counter and store it in the EEPROM.
Nick
