Dot Matrix LED
prayami
Dot Matrix LED
PostPosted: Sun Jan 09, 2005 9:55 pm     Reply with quote
Hi...
I am using Dot Matrix LED with 18F4525. Everything is working fine. But
one little odd thing I can see is: One dot on the right hand bottom corner
is brighter than all other dots.
(1)
It would be better, if we can brighter all the dots like that or
(2)
Just adjust that dot as the same brightness as of the others.
I tried a lot but could not find out the reason.
I have not used any register with Dot Matrix LEDs.
And have delay of 50us after turning each dot on.
Can anybody have suggestion to solve this? Or know the reason?
Mark
PostPosted: Sun Jan 09, 2005 10:39 pm     Reply with quote
If you are multiplexing the LEDs then it is your code. Try posting a small example that demonstrates the problem.
