LCD (HD44780) device on an I2C MCP23016 I/O expander.
hatanet
PostPosted: Tue Sep 30, 2003 8:01 am     Reply with quote
Ole,
I am trying to implement an LCD (HD44780) device on an I2C MCP23016 I/O expander, using a PIC18F452. I have gone through Microchip AN245, tried to change most of the Hi-Tech code to CCS... But no luck!
Has anyone ever tried such a thing and how do I make mine work?
Regards
Hatanet
Mark
PostPosted: Tue Sep 30, 2003 9:33 am     Reply with quote
Post what you have and maybe someone can spot what is wrong.
hatanet
PostPosted: Wed Oct 01, 2003 1:49 am     Reply with quote
I have included two files...
Here is the MCP23016.C file:
#use standard_io(C)
#use i2c(master,sda=PIN_C4,scl=PIN_C3)
// COMMAND BYTE TO REGISTER RELATIONSHIP : Table: 1-3 of Microchip MCP23016 - DS20090A
#define GP0 0x00
#define GP1 0x01
#define OLAT0 0x02
#define OLAT1 0x03
#define IPOL0 0x04 // INPUT POLARITY PORT REGISTER 0
#define IPOL1 0x05 // INPUT POLARITY PORT REGISTER 1
#define IODIR0 0x06 // I/O DIRECTION REGISTER 0
#define IODIR1 0x07 // I/O DIRECTION REGISTER 1
#define INTCAP0 0x08 // INTERRUPT CAPTURE REGISTER 0
#define INTCAP1 0x09 // INTERRUPT CAPTURE REGISTER 1
#define IOCON0 0x0A // I/O EXPANDER CONTROL REGISTER 0
#define IOCON1 0x0B // I/O EXPANDER CONTROL REGISTER 1
// BLOCK VARIABLE REGISTER
unsigned char MCP23016_Device_Address; // MCP23016 Assigned Device Address.
int GPIO_port; // MCP23016 Data Port Register.
// MCP23016 - I2C constants for selecting type of data transfer.
#define I2C_MCP23016_GP0_READ 0x9F // 1001 1111
#define I2C_MCP23016_GP0_WRITE 0x9E // 1001 1110
#define I2C_MCP23016_GP1_READ 0x9F // 1001 1111
#define I2C_MCP23016_GP1_WRITE 0x9E // 1001 1110
void write2Expander(unsigned char WriteAddress, unsigned char cmdByte, unsigned char lsbData, unsigned char msbData)
short int status;
i2c_start(); // start condition
delay_us(20);
i2c_write(WriteAddress); // Send slave address and clear (R/W_)
delay_us(20);
i2c_write(cmdByte); // Command byte and register to be written.
delay_us(20);
i2c_write(lsbData); // First data byte pair as per command byte(cmd)
delay_us(20);
i2c_write(msbData); // Second data byte pair as per command byte(cmd)
delay_us(20);
i2c_stop(); // stop condition
delay_us(50); // delay to allow write (12us)min.
// FORCE WRITING
/* i2c_start(); // restart condition
status=i2c_write(WriteAddress);
while(status==1)
status=i2c_write(WriteAddress); // force writing
unsigned char readExpander(unsigned char WriteAddress, unsigned char ReadAddress, unsigned char cmdByte)
unsigned char Data, lsbData, msbData;
short int status,count;
startRead:
count=0; // Initialize read attempts counter.
i2c_write(ReadAddress); // Send slave address and clear (R_/W)
lsbData = i2c_read(1); // Data from LSB or MSB of register
msbData = i2c_read(0); // Data from MSB or LSB of register
delay_us(50); // delay to allow read (12us)min.
// There is no limitation on the no. of data bytes in one read transmission, so wait until all is read.
status=i2c_read(1);
while(status==1)
status=i2c_read(1); // force reading
// Otherwise start reading process all over again after 100 read attempts
if (status==1 && count==100 )
goto startRead; // timeout restart
count+=1;
// Combine two 8-bit data lengths into one 16-bit word length as a return value.
combiner:
data=lsbData;
data=data*9;
if((msbData&0x80)!=0)
data=data+4;
data=(data/5)+32;
msbData=data;
return(msbData); // return read value
void init_mcp23016(unsigned char MCP23016_Device_Address)
// Wait for MCP23016 Expander Device to power-up.
delay_ms(250);
delay_ms(250);
delay_ms(250);
// Set-up selected I/O expander unit
//write2Expander(MCP23016_Device_Address, IPOL0, 0xFF, 0xFF); // Invert all input polarities if active low.
//write2Expander(MCP23016_Device_Address, IPOL1, 0xFF, 0xFF); // Invert all input polarities if active low.
write2Expander(MCP23016_Device_Address, IPOL0, 0x00, 0x00); // NonInvert all input polarities if active low.
write2Expander(MCP23016_Device_Address, IPOL1, 0x00, 0x00); // NonInvert all input polarities if active low.
write2Expander(MCP23016_Device_Address, IOCON0, 0x01, 0x01); // IARES(1) to max. activity detection time.
write2Expander(MCP23016_Device_Address, IODIR0, 0x00, 0x00); // Direction of all data is output.
write2Expander(MCP23016_Device_Address, IODIR1, 0x00, 0x00); // Direction of all data is output.
write2Expander(MCP23016_Device_Address, OLAT0, 0xFF, 0xFF); // Update o/p latch that controls the output.
write2Expander(MCP23016_Device_Address, OLAT1, 0xFF, 0xFF); // Update o/p latch that controls the output.
//write2Expander(MCP23016_Device_Address, IODIR0, 0x00, 0x00); // Direction of all data is output.
//write2Expander(MCP23016_Device_Address, IODIR1, 0x00, 0x00); // Direction of all data is output.
Here is the LCD23016.C File
struct lcd_pin_map { // This hatanet structure is overlayed
boolean unused; // on to an I/O port to gain
boolean enable; // access to the LCD pins.
boolean rw; // The bits are allocated from
boolean rs; // low order up. ENABLE will
int data : 4; // be pin B1.
} lcd;
#if defined(__PCH__)
#byte lcd = 0xF81 // This puts the entire structure
#else // on to port B (at address 6)
#byte lcd = 6
#endif
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
//STRUCT lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
//STRUCT lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
byte lcd_read_byte(int GPIO_port) {
byte low,high,runx;
if (GPIO_port=0) {
//set_tris_b(LCD_READ);
// write2Expander(MCP23016_Device_Address, IODIR0, LCD_READ, 0x00); // Direction of all data is output.
write2Expander(MCP23016_Device_Address, IODIR0, 0xF0, 0x00); // Direction of all data is output.
//lcd.rw = 1;
runx = runx | 0x03;
write2Expander(MCP23016_Device_Address, GP0, runx, 0x00); // Enable lcd module.
delay_cycles(1);
//lcd.enable = 1;
runx = runx | 0x02;
delay_cycles(1);
high = lcd.data;
//lcd.enable = 0;
runx = runx & 0xfd;
write2Expander(MCP23016_Device_Address, GP0, runx, 0x00); // Disable lcd module.
delay_cycles(1);
//lcd.enable = 1;
runx = runx | 0x02;
delay_us(1);
low = lcd.data;
//lcd.enable = 0;
runx = runx & 0xfd;
//set_tris_b(LCD_WRITE);
write2Expander(MCP23016_Device_Address, IODIR0, LCD_WRITE, 0x00); // Direction of all data is output.
return( (high<<4) | low);
} Else if (GPIO_port=1) {
write2Expander(MCP23016_Device_Address, IODIR1, LCD_READ, 0x00); // Direction of all data is output.
//lcd.rw = 1;
runx = runx | 0x03;
write2Expander(MCP23016_Device_Address, GP1, runx, 0x00); // Enable lcd module.
delay_cycles(1);
//lcd.enable = 1;
runx = runx | 0x02;
delay_cycles(1);
high = lcd.data;
//lcd.enable = 0;
runx = runx & 0xfd;
write2Expander(MCP23016_Device_Address, GP1, runx, 0x00); // Disable lcd module.
delay_cycles(1);
//lcd.enable = 1;
runx = runx | 0x02;
delay_us(1);
low = lcd.data;
//lcd.enable = 0;
runx = runx & 0xfd;
write2Expander(MCP23016_Device_Address, IODIR1, LCD_WRITE, 0x00); // Direction of all data is output.
void lcd_send_nibble(byte n, int GPIO_port) {
byte runx;
if (GPIO_port=0) {
//lcd.data = n;
runx = n & 0xff;
write2Expander(MCP23016_Device_Address, GP0, runx, 0x00); // Send actual data.
delay_cycles(1);
//lcd.enable = 1;
runx = runx | 0x02;
delay_us(2);
//lcd.enable = 0;
runx = runx & 0xfd;
//lcd.data = n;
runx = n & 0xff;
write2Expander(MCP23016_Device_Address, GP1, runx, 0x00); // Send actual data.
delay_cycles(1);
//lcd.enable = 1;
runx = runx | 0x02;
delay_us(2);
//lcd.enable = 0;
runx = runx & 0xfd;
} //else
void lcd_send_byte( byte address, byte n, int GPIO_port) {
lcd.rs = 0;
while ( bit_test(lcd_read_byte(),7) ) ;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
byte runx;
if (GPIO_port=0) {
//lcd.rs = 0;
runx = runx & 0xf7;
while ( bit_test(lcd_read_byte(0),7) ) ;
//lcd.rs = address;
runx = runx | (address >> 3);
delay_cycles(1);
//lcd.rw = 0;
runx = runx & 0xfb;
delay_cycles(1);
//lcd.enable = 0;
runx = runx & 0xfd;
lcd_send_nibble(n >> 4, GPIO_port);
lcd_send_nibble(n & 0xf, GPIO_port);
//lcd.rs = 0;
runx = runx & 0xf7;
//lcd.rs = address;
delay_cycles(1);
//lcd.rw = 0;
runx = runx & 0xfb;
delay_cycles(1);
//lcd.enable = 0;
runx = runx & 0xfd;
} //else
void init_exp_lcd(unsigned char MCP23016_Device_Address, int GPIO_port) {
byte i, runx=0;
if (GPIO_port=0) {
// Set-up expander port.
write2Expander(MCP23016_Device_Address, OLAT0, 0x00, 0x00); // Update o/p latch that controls the output.
// write2Expander(MCP23016_Device_Address, IODIR0, 0x00, 0x00); // Direction of all data is output.
// Set-up LCD orientation.
// write2Expander(MCP23016_Device_Address, IODIR0, LCD_WRITE, 0x00); // Direction of all data is output.
write2Expander(MCP23016_Device_Address, IODIR0, 0x00, 0x00); // Send actual data.
//lcd.rs = 0;
// runx = runx & 0xf7;
// write2Expander(MCP23016_Device_Address, GP0, runx, 0x00); // Disable lcd module.
//lcd.rw = 0;
// runx = runx & 0xfb;
//lcd.enable = 0;
// runx = runx & 0xfd;
write2Expander(MCP23016_Device_Address, GP0, 0x00, 0x00); // Send actual data.
delay_ms(15);
for(i=1;i<=3;++i) {
// lcd_send_nibble(3,GPIO_port);
lcd_send_nibble(3 >> 4,GPIO_port);
delay_ms(5);
lcd_send_nibble(2 >> 4,GPIO_port);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i],GPIO_port);
} else if (GPIO_port=1) {
write2Expander(MCP23016_Device_Address, OLAT1, 0x00, 0x00); // Update o/p latch that controls the output.
// write2Expander(MCP23016_Device_Address, IODIR1, 0x00, 0x00); // Direction of all data is output.
// write2Expander(MCP23016_Device_Address, IODIR1, LCD_WRITE, 0x00); // Direction of all data is output.
//lcd.rs = 0;
// write2Expander(MCP23016_Device_Address, GP1, runx, 0x00); // Disable lcd module.
//lcd.rw = 0;
//lcd.enable = 0;
write2Expander(MCP23016_Device_Address, GP1, 0x00, 0x00); // Send actual data.
delay_ms(15);
for(i=1;i<=3;++i) {
delay_ms(5);
for(i=0;i<=3;++i)
} //else if
void lcd_gotoxy( byte x, byte y) {
byte address;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
void lcd_gotoxy( byte x, byte y, int GPIO_port) {
byte address;
if(y!=1)
address=0;
address+=x-1;
lcd_send_byte(0, 0x80|address, GPIO_port);
void expander_lcd_putc( char c, int GPIO_port) {
switch (c) {
case '\f' : lcd_send_byte(0, 1, GPIO_port);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2, GPIO_port); break;
case '\b' : lcd_send_byte(0,0x10, GPIO_port); break;
default : lcd_send_byte(1,c, GPIO_port); break;
1}
char lcd_getc( byte x, byte y, int GPIO_port) {
char value;
lcd_gotoxy(x,y,GPIO_port);
lcd.rs=1;
value = lcd_read_byte(0);
lcd.rs=0;
return(value);
MGLSOFT
PostPosted: Wed Jan 05, 2005 4:42 pm     Reply with quote
startRead:
i2c_stop();//here is the problem. sorry no speak english
