timer0 external input
johnl
PostPosted: Wed Dec 29, 2004 8:50 pm     Reply with quote
In simulation, timer 1 counts external pulses from a switch properly, but timer 0 does not. Is there something I am missing with the code? (if not then it's probably my simulator.)
The compiler is version 3.214.
/////////  timer0bug.c ///////////////////////////
#include <18F452.h>
#FUSES HS,NOBROWNOUT,NOWDT,NODEBUG,NOLVP,NOPROTECT
#byte PORTB=0xF81
#byte PORTD=0xF83
void portinit(void);
main()
   portinit();
   setup_timer_0(RTCC_EXT_L_TO_H);
   setup_timer_1(T1_EXTERNAL  );
   set_timer0(0);
   set_timer1(0);
         PORTB=(byte)get_timer0();
         PORTD=(byte)get_timer1();
portinit()
   set_tris_a(0b00010000);      // all port A outputs except A4 for timer0  input
   set_tris_b(0b00000000);      // all port B outputs
   set_tris_c(0b00000001);      // all port C outputs except C0 for timer1  input
   set_tris_d(0b00000000);      // all port D outputs
   set_tris_e(0b00000000);      // all port E outputs
Haplo
PostPosted: Thu Dec 30, 2004 5:45 am     Reply with quote
Keep in mind that RA4/T0CKI pin is a Schmitt Trigger input and an open drain output. All other RA port pins have TTL input levels and
full CMOS output drivers.
Re: timer0 external input
PostPosted: Thu Dec 30, 2004 6:47 am     Reply with quote
Check the prescalers.
Timer0 can only count every other pulse.
Timer1 can count all pulses.
setup_timer_0(RTCC_EXT_L_TO_H | RTCC_DIV_2);
setup_timer_1(T1_EXTERNAL | T1_DIV_BY_1);
PostPosted: Thu Dec 30, 2004 7:17 am     Reply with quote
I guess that Guest meant that in your example program the Timer0 is configured to divide by 2. If you don't specify the prescaler value, then it defaults to a divide by 2, a stupid default value.
If you want timer0 not to divide the input signal, then configure it as
setup_timer_0(RTCC_EXT_L_TO_H | RTCC_DIV_1);
johnl
PostPosted: Thu Dec 30, 2004 8:35 am     Reply with quote
The prescaler doesn't seem to be an issue since timer0 is not counting at all. Port B always shows a count of zero (the pre-loaded value) regardless of the number of input pulses.
Haplo, A4 is an input so the open drain doesn't matter. I tested the A4 pin as an input and it works. I also tested timer0 with the internal clock and it works. I just can't get the A4 pin to work as an input to timer0.
It seems like thing are pointing to my simulator....
Thanks to all.
ljbeng
PostPosted: Thu Dec 30, 2004 9:04 am     Reply with quote
I am using the 18F4620 and RA4 is incrementing timer 0 just fine. If you look at the chip data book, reading timer 0 (get_timer0()) will return a 16 bit value and is prescaled 2:1.
johnl
PostPosted: Thu Dec 30, 2004 9:09 am     Reply with quote
ljbeng - Are you using similar code (or my code)?
johnl
PostPosted: Thu Dec 30, 2004 7:14 pm     Reply with quote
I just confirmed that it does work in hardware -so the simulator has a problem.
Thanks to all who responded.
Happy New Year.
Haplo
PostPosted: Fri Dec 31, 2004 2:21 am     Reply with quote
What simulator are you using?
johnl
PostPosted: Fri Dec 31, 2004 8:45 am     Reply with quote
I am using Proteus VSM. Overall it works well and saves developing time. It's really handy to work out many code and hardware issues without having to prototype hardware.
Some of the models for PIC12 and PIC18 have bugs but they are working on that.
John
