newbie question
newbie question
PostPosted: Wed Dec 22, 2004 10:26 am     Reply with quote
i am trying to flash an LED. using a PIC16f84a, the code works fine. but same code doesnt work for a PIC18f452???
#include <18F452.h>
#device adc=8
#fuses NOWDT,WDT128,XT, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, LVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   while (1) {
      output_high(PIN_B4);
      output_low(PIN_B4);
what am I missing here?
PostPosted: Wed Dec 22, 2004 10:53 am     Reply with quote
I forgot to tell you what is exactly the problem. the problem is that all the LED is not flashing, and is lit.
PostPosted: Wed Dec 22, 2004 1:37 pm     Reply with quote
1. Change the "LVP" fuse to "NOLVP", unless you know for sure
that you're using a Low Voltage Programmer. 99% of users
do not use a LVP programmer, and so should set it to NOLVP.
2. Normally the RS232 is 8 bits. Is there a reason why you
have it set to 9 bits ?
