object01
Joined: 13 May 2004 Posts: 90 Location: Nashville, TN
Detecting #use fast_io |
Posted: Tue Dec 21, 2004 9:52 am |
I've recently been frustrated by the output_*() functions only accepting constants as parameters. I'm trying to build a multi-mode driver that handles a variable number of FLASH RAMs on SPI, configurable at compile-time, and selecting/deselecting chip-select lines is a little tedious now. So I thought about writing my own output_functions that do the same thing, but I need to be able to detect whether #use fast_io is in effect. I didn't see anything for detecting this using getenv(). Is there a way?
Jeff S. |
Posted: Tue Dec 21, 2004 10:36 am |
Quote: | I've recently been frustrated by the output_*() functions only
accepting constants as parameters |
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=18480
Quote: | but I need to be able to detect whether #use fast_io is in effect. |
Something like this would probably work. If you don't want to use
fast_io, then comment out the #define statement.
Code: | #include <16F877.h>
#fuses XT, NOWDT, PUT, BROWNOUT, NOLVP
#define USE_FAST_IO_B 1
#ifdef USE_FAST_IO_B
#use fast_io(B)
// Put your code here.
