I'm trying to use Bloader from Sparkfun to load CCS C generated code. The readme file says the program must start at memory location 0x0004 and the interrupt vector will still operate properly from the same location. How can I change the program to do this? The only thing I could find on this was to use: #build (reset = 0x1, interrupt = 0x05)
#org 0x0f00,0x0fff{}
I'm throughly confused by this and would appreciate any suggestions!
It's strange that Sparkfun wrote their bootloader in CCS,
but don't offer instructions on how to use it with CCS.
RodP Guest
Thanks for response
Posted: Wed Dec 22, 2004 9:12 am
Thanks to PCM Programmer. I was wanting to use this with a 16F88 and it appears that isn't an option. Maybe CCS will sell a reasonably priced bootloader for use with their compiler that's able to work with MPLAB as the ICD.
