How do I create a lookup table using arrays?
SlimG
PostPosted: Wed Dec 22, 2004 1:36 pm     Reply with quote
hi there, i am trying to create a lookup table that would display numbers between 0 and 360 on three multiplexed 7segment displays, using arrays.
any ideas or sample codes please? thanx
rwyoung
PostPosted: Wed Dec 22, 2004 3:26 pm     Reply with quote
Here are two possiblities for representing how to light the segments. I didn't bother putting in the 1's vs 0's since I don't know how you are wired up so just fill in the table appropriately.
const int8 seg7[10][7] =
//g,f,e,d,c,b,a
{ 0,0,0,0,0,0,0, // 0
  0,0,0,0,0,0,0, // 1
  0,0,0,0,0,0,0, // 2
  0,0,0,0,0,0,0, // 3
  0,0,0,0,0,0,0, // 4
  0,0,0,0,0,0,0, // 5
  0,0,0,0,0,0,0, // 6
  0,0,0,0,0,0,0, // 7
  0,0,0,0,0,0,0, // 8
  0,0,0,0,0,0,0  // 9
In this example, I used a 2d array where each column element represents a single segment. This is pretty inefficient (70 bytes) but depending on how you are controlling the display, it may work better than the more straight forward version below.
const int8 seg7b[10] =
//   gfedcba
{ 0b00000000, // 0
  0b00000000, // 1
  0b00000000, // 2
  0b00000000, // 3
  0b00000000, // 4
  0b00000000, // 5
  0b00000000, // 6
  0b00000000, // 7
  0b00000000, // 8
  0b00000000  // 9
Here I only used 10 bytes and each byte would have its bits encoded to a particular segment LED.
To get the magic word for a number, you will take apart the number to find the 100's, 10's and 1's. You can tweak the display code for leading zero blank.
If you want a single table to hold all possible combinations, you can expand the second example to be either a 3 x 361 array of int8's or a 361 entry array of int32s and waste one byte of the 32-bit word. You may run into memory allocation problems with an array of this size, depending on the PIC chip you have selected.
Unless I had no other choice, I'd use a small table to represent the 10 combinations I need for a single digit and just make 3 passes through the table.
Rob Young
