hello, i am new in the pic bussines and i have a problem. i use the 16f628a with an internal clock, a switch with an 10kohm resistant(pull down) on the RB0 - EXT_INT and a transistor to switch on a led.
the problem is that the systems works perfect when i pull my finger on the chip and it doesn't work when i give my hand away.
ext_int_edge(H_TO_L); // init interrupt triggering for button press
enable_interrupts(INT_EXT);// turn on interrupts
set_tris_a(0);
set_tris_b(0b00000001); // RB0 wird als Eingang definiert
while (1)
output_low(PIN_B3); //LED wird auf LOW gesetzt
output_high(PIN_B3);
simple, but it doesn't work.
thanks for help!
Posted: Thu Dec 16, 2004 2:00 pm
The problem is that the systems works perfect when i pull my finger on the chip and it doesn't work when i give my hand away.
Two possible solutions:
1. Add NOLVP to the end of the #fuses statement.
2. Make sure that the MCLR pin is connected to your Vdd voltage
(probably +5v in your case) through a resistor. The resistor
value could be 10K, but if you are using the CCS ICD, then it
should be 47K.
Posted: Thu Dec 16, 2004 6:58 pm
make sure your switch is held high and grounds when button pressed. i had a similar problem with a pic because i was letting the pins float and they would go high when a hand was waved near the circuit.
