NOT ENOUGH RAM
ccmcca
NOT ENOUGH RAM
PostPosted: Mon Oct 25, 2004 12:05 pm     Reply with quote
What i have to do with this error?
SherpaDoug
PostPosted: Mon Oct 25, 2004 1:17 pm     Reply with quote
1) See how much RAM your chip has.
2) See how much RAM all your variables and data structures take.
3) Allow a little for compiler scratchpad if you are using any complex lines of code.
If it doesn't fit you need to:
1) Use a bigger chip.
2) Use fewer variables, reuse variables, use shorts instead of ints, use smaller buffers etc.
3) Use simpled C lines so the compiled doesn't need so much scratchpad.
PostPosted: Mon Oct 25, 2004 2:01 pm     Reply with quote
And, for most chips in the 16-series, with the PCM compiler you
can enable use of all RAM with the #device *=16 statement, as
shown below:
#include <16F877.H>
#device *=16     //  <== Add this line, at this exact location.
#use delay(clock = 4000000)
ccmcca
THANKS
PostPosted: Mon Oct 25, 2004 7:35 pm     Reply with quote
Eso era el problema amigos!!!!!!!!!!!!!!!!!!!!!!!!!!
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Stephanfo
Thanks, soooooo much
PostPosted: Sun Dec 12, 2004 2:49 pm     Reply with quote
I was looking for why I was out of memory with only half of used variable.
And I found this post.
I always asked me for the interest of this option, now I know Wink
Thanks a lot for your help
Stephanfo
