Herry Guest
probrem with detecting PWM width |
Posted: Tue Dec 14, 2004 3:11 am |
Hello everyone..
Now I would like to detect PWM width without use CCP1 and CCP2
my plane is use hardware to detect ..
when input(PIN_A0)=1 // high-->set_timer1(0)
then....
input(PIN_A0)=0// low-->get_timer1
one PWM period is 10ms
but can't work.....It seems something wrong on my code...
plz help me to check....thank you very much
#include <18f458.h>
#fuses HS,NOLVP,NOWDT,PUT
#use delay(clock=16000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,stream=hostpc)
#use fast_io(A)
int width;
main()
setup_timer_1(T1_INTERNAL);
set_tris_a(0xff);
while(input(PIN_A0))
set_timer1(0);
while(input(!PIN_A0)) // wait signal until fall
width=get_timer1();
printf("pwm with is %d \n\r",width);
drh
Joined: 12 Jul 2004 Posts: 192 Location: Hemet, California USA
Posted: Tue Dec 14, 2004 8:39 am |
Try this...
Main() {
set_tris_a(0xFF);
setup_timer1(T1_INTERNAL);
while (TRUE) {
while (!input(PIN_A0)) // wait for high
set_timer1(0); // restart timer
while (input(PIN_A0)) // wait for low
width = get_timer1();
printf("pwm width is %d \n\f", width);
_________________ David |
