Fast page read/write routines for i2c EEPROMS
Post new topic   Reply to topic    CCS Forum Index -> Code Library
dvdb
PostPosted: Thu Dec 23, 2004 12:19 pm     Reply with quote
The drivers for the 24LCXX EEPROMS provided by CCS do not contain fast multibyte read/write routines. The multibyte reads are quite straightforward, but the multibyte write routines are a little more tricky since they have to stay within a page.
The snippet that I provide here will check page crossing and split up the write into the minimal number of page writes.
I didn't check but I suspect writing large amounts of data will speed up as much as a factor of 100 (for a 128-byte page) compared to single byte writes.
Mind the i2c address - EEPROM2 is 2*address
Enjoy!
#define pagesize 128
#define pagemask ~((long)pagesize-1) //this is for the 24LC512
#define hi(x)  (*(&x+1))
#define EEPROM2 0b00001100
#define control_byte_read 0xa1
#define control_byte_write 0xa0
void init_ext_eeprom() {
   output_float(PIN_C4);
   output_float(PIN_C3);
BOOLEAN ext_eeprom2_ready() {
   int1 ack;
   i2c_start();            // If the write command is acknowledged,
   ack = i2c_write(control_byte_write|EEPROM2);  // then the device is ready.
   i2c_stop();
  return !ack;
void write_ext_eeprom2(long int address, BYTE data) {
  while(!ext_eeprom2_ready());
   i2c_start();
   i2c_write(hi(address));
   i2c_write(address);
   i2c_write(data);
   i2c_stop();
BYTE read_ext_eeprom2(long int address) {
   BYTE data;
   i2c_start();
   i2c_write(address);
   i2c_start();
   i2c_write(control_byte_read|EEPROM2);
   data=i2c_read(0);
   i2c_stop();
   return(data);
void multiread_ext_eeprom2(long int address, int number, int* dest )
   if(number>0)
   i2c_start();
   i2c_write(address);
   i2c_start();
   while (number>1)
   {*dest=i2c_read(1); //1 because do ACK after each byte read
   dest++;
   number--;
   *dest=i2c_read(0); //0 because no ACK
   i2c_stop();
void multiwrite_ext_eeprom2(long int address, int number, int* data )
{  long strt_adress;
   while(number!=0)
   strt_adress=address&pagemask;
   i2c_start();
   i2c_write(address);
   while ((number!=0)&&((address&pagemask)==strt_adress))
      {i2c_write(*data);
      data++;
      number--;
      address++;
   i2c_stop();
Dirk Van den Berge
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
