problems with A/D interrupts
PostPosted: Fri Dec 03, 2004 7:33 am     Reply with quote
I need to use A/D interrupt to measure a value of voltage from variable resistance to find its max or min while I'm doing another task.
But, my code may be wrong. I can only hear the song but PIC doesn't give a value of max and min to me.
I'm not sure about int_ad and ad_isr.
What I use in the code is correct ??
thank you Very Happy
#device ADC=10
boolean hook_ad=false;
void ad_isr();
#int_ad
void ad_isr()
   hook_ad = true;
   long duration;
   int16 i, value, min, max, avg, rate;
   enable_interrupts(INT_AD);
   setup_port_a(ALL_ANALOG);
   set_adc_channel(0);     // PIN 2
      min=1023;
      max=0;
   if(hook_ad)
         value = Read_ADC();
         printf(lcd_putc, "%ld", value);
         printf(lcd_putc, "\f");
         if(value<min)
            min=value;
         if(value>max)
            max=value;
         hook_ad=false;
         PlaySong(200);
PostPosted: Fri Dec 03, 2004 7:50 am     Reply with quote
You have to tell the ADC to start a conversion. See the example in the manual for the read_adc command.
also: setup_port_a() is an obsolete function name, the new name is SETUP_ADC_PORTS
Mark
PostPosted: Fri Dec 03, 2004 8:03 am     Reply with quote
You problem is that you PIC has went to bed Very Happy The problem is not telling the adc to start. The default for ADC_READ() is ADC_START_AND_READ which you don't want.
#device ADC=10
void ad_isr();
#int_ad
void ad_isr()
   hook_ad = true;
   long duration;
   // Setup the port first
      min=1023;
      max=0;
   // Start the initial conversion
   Read_ADC(ADC_START_ONLY);
     if(hook_ad)
           // Only read the value
           value = Read_ADC(ADC_READ_ONLY);
           if(value<min)
              min=value;
           if(value>max)
              max=value;
           hook_ad=false;
           // Start the next conversion
           PlaySong(200);
future
PostPosted: Fri Dec 03, 2004 2:49 pm     Reply with quote
You may want to see my other thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=21119
Mark
PostPosted: Fri Dec 03, 2004 4:44 pm     Reply with quote
Am I missing something? That doesn't even use interrupts.
future
PostPosted: Fri Dec 03, 2004 5:18 pm     Reply with quote
The way the previous code is structured, using an inline function will work the same way without using interrupts.
Using them, it will have to go through all the interrupt dispatcher (almost 100 instructions) just to set a flag and still handle the read in main().
I think it is much like the thread I commented.
He says "while doing another task", we know that this is not possible. So call the function twice with a delay between calls and its done.
Depending on the PIC clock he is using, probably hook_ad is always true and the read will be limited by the main loop speed... so use an inline function and get higher speeds without spending time in the dispatcher.
This is just my opinion and how I would solve this problem.
Mark
PostPosted: Fri Dec 03, 2004 5:43 pm     Reply with quote
I see it as an exercise for using ints Wink
