| View previous topic :: View next topic   |
			alexz
				| Error |
				 Posted: Thu Dec 02, 2004 9:16 am     |
				Getting the following error:
Halting build on first failed translation as user preferences indicate.
What does it mean? _________________ Alex |
			rwyoung
  Joined: 12 Nov 2003 Posts: 563 Location: Lawrence, KS  USA
				 Posted: Thu Dec 02, 2004 9:21 am     |
				It means you have an error in your C code and the compiler's preferences are set to stop the compiling process at the first error.
Post your code if you cannot find the error yourself. _________________ Rob Young
			alexz
				 Posted: Thu Dec 02, 2004 9:29 am     |
				 	  | rwyoung wrote: | 	 		  It means you have an error in your C code and the compiler's preferences are set to stop the compiling process at the first error.
Post your code if you cannot find the error yourself. |
#device	PIC16F877 *=16 	ADC=8
#include	"SFR.h"
#define     CHANNEL0    0x01
#define     CHANNEL1    0x07
unsigned char Press0;
unsigned char Press1;
unsigned char result;
void main(void);
void Init(void);
void InitADC(void);
void InitSerial(void);
void  WriteByte(unsigned char) ;
void ADC_isr(void) ;
		Init();
		Press0 = 0;
	    	Press1 = 0;
		enable_interrupts(INT_AD);
		Read_ADC(ADC_START_ONLY);
void  WriteByte(unsigned char TxByte )
	while ((TXSTA & 2) == 0)// && CommsTimer < 100)// Wait until end of TXD
	//	CLRWDT();
	TXREG = TxByte;
void Init(void)
	 TRISA = 0xFF;
	 TRISC = 0xFE;
	  InitADC();
	  InitSerial();
void InitADC(void)
  	 setup_adc_ports(RA0_RA1_RA3_ANALOG);
	setup_adc(ADC_CLOCK_INTERNAL );
	set_adc_channel(0);
	disable_interrupts(INT_AD);
	TXSTA = 0x24 ;
	RCSTA = 0x90 ;
	SPBRG = 12;        // set to 19.2 kBaud, using 19.66 MHz clock
#int_AD
ADC_isr()
	PIR1bits.ADIF = 0;
	Press0 = ADRESH ;
	WriteByte(Press0);
} _________________ Alex |
			alexz
				 Posted: Thu Dec 02, 2004 9:32 am     |
				The following code gives the same error:
#include	"SFR.h"
void main ()
That's why I dont think there is anything to do with the code
I am using the new MPLAB v7.00 _________________ Alex |
			Mark
				 Posted: Thu Dec 02, 2004 10:07 am     |
				| Well you didn't post the sfr.h file so I just made some stuff up.  But it compiled just fine with MPLAB v7.0. |
			alexz
				 Posted: Thu Dec 02, 2004 10:25 am     |
				 	  | Mark wrote: | 	 		  | Well you didn't post the sfr.h file so I just made some stuff up.  But it compiled just fine with MPLAB v7.0. |
The SFR.h is alright, use it all the time.
I have installed the older version of MPLAB v6.
and compiled it ok.
What would you say about that? _________________ Alex |
			Mark
				 Posted: Thu Dec 02, 2004 10:28 am     |
				I'd say mine works and yours doesn't
Check to make sure you have the latest plugin |
			alexz
				 Posted: Thu Dec 02, 2004 11:03 am     |
				 	  | Mark wrote: | 	 		  I'd say mine works and yours doesn't
Where can I get it? _________________ Alex |
			Humberto
				 Posted: Thu Dec 02, 2004 11:42 am     |
				 	  | Quote: |
Where can I get it?
IMO, this is not the lane.
First as rwyoung suggest you, modify the compiler preferences to
no to stop at the very first error found, select:
Error Files  [/b[b]]>--  Multi-Lines then when you know
what kind of error you are dealing with, make the corrections.
Best wishes,
Humberto |
			Mark
				 Posted: Thu Dec 02, 2004 12:45 pm     |
				 	  | Quote: | 	 		  IMO, this is not the lane.
There is not a problem with the code.  See his post above:
 	  | Quote: | 	 		  I have installed the older version of MPLAB v6.
and compiled it ok.
			Mark
				 Posted: Thu Dec 02, 2004 12:46 pm     |
				 	  | alexz wrote: | 	 		   	  | Mark wrote: | 	 		  I'd say mine works and yours doesn't
Where can I get it? |
Try the download section from CCS.  Of course the new version of MPLAB might already have it. |
			Humberto
				 Posted: Thu Dec 02, 2004 2:02 pm     |
				 	  | Quote: |
Hi Mark,
I didnīt mention anything regarding the code,
but the compiler options and the procedure.
Humberto |
			Mark
				 Posted: Thu Dec 02, 2004 2:22 pm     |
				 	  | Quote: | 	 		  Multi-Lines then when you know
what kind of error you are dealing with, make the corrections |
 	  | Quote: | 	 		  | I didnīt mention anything regarding the code |
Well he is getting some error when compiling.  Now nothing is wrong with the code since it compiles just fine on my machine.  Whether or not he stops the compile on the first error isn't going to fix the problem or show him what the problem is.  He shouldn't get any errors since it compiles just fine for me.  Also, it compiles with the old MPLAB so there must be some sort of installation problem or incorrect setup (not whether or not the compile stops on the first error). |
