Newbie Guest
Voltage levels |
Posted: Wed Nov 24, 2004 5:40 pm |
I want to run a 18F252 at 3.5v along with a GM862 GSM modem but I think there is an issue with level conversion as the GM862 has a maximum 2.8v for the interface can anyone advise me? do I mmet conversion?
Thx
Pete |
Newbie Guest
Did I ask the wrong question? |
Posted: Thu Nov 25, 2004 4:38 am |
Hi again,
I notice losts of people looking at my post but nobody answering, am I asking the wrong question or is it that simple you think I'm stupid?
I'm just unsure if I need voltage level shifters for the RS232 and I/O control to this device (max 2.8v) whilst running a PIC at 3.5v
Anyone? |
Steve Lomas Guest
Posted: Thu Nov 25, 2004 7:31 am |
The 18F252 has a 4.2V minimum so will not run at 3.5V.
The 18LF252 will do as you require but with limitations on the max clock frequency.
I'm just developing a module with an 18F252 & GM862, I'm running the PIC at 5V and the GM862 from a LiIon battery. To acheive the level shifting I have used the BCR22 devices as per the Telit documentation.
Hope this helps. |
Guest Guest
Thanks |
Posted: Thu Nov 25, 2004 5:20 pm |
OK, so if I used the 18LF252 at say 3v and at 4mhz would I need level shifters for the RS232 link to the GM862?
P.S. Sorry to be such a newb |
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Thu Nov 25, 2004 5:50 pm |
In the GM862 datasheet section 7.1 "Using GPIO as input" it explains how to perform the necessary level conversion. |
Posted: Fri Nov 26, 2004 3:18 am |
For a similar application in the past, I used the MAX3372.
Newbie Guest
So.... |
Posted: Fri Nov 26, 2004 5:21 pm |
So although you didn't say it, I assume from the last couple of replies that even if I run the 18LF252 at 3v I still need to level [censored] to work with the GM862 at 2.8v?
Thanks |
Newbie Guest
Oops |
Posted: Sat Nov 27, 2004 8:07 am |
I mean shifters!!!!! |
Re: Oops |
Posted: Sat Nov 27, 2004 9:49 am |
Newbie wrote: | I mean shifters!!!!! |
You'd have to look carefully at both data sheets, for the input high, input low, output high, and output low levels. I'd have expected it might well work, but has already been pointed out, it restricts the available clock rate rather. Also if (for instance), you want to do a bootloader, there are problems at the lower voltage levels...
