Guest Guest
| malloc not working |
Posted: Thu Nov 25, 2004 7:48 pm |
Someone from CCS, I need to know how __DYNAMIC_HEAD works.
Somehow, when I call the malloc function, it keeps looping and never returns anything.
char *malloc(size_t size)
node_t *node,*new;
long nsize;
node=__DYNAMIC_HEAD;
while(node!=NULL) // chk until end of memlist
if(!bit_test(node->size,pos) && node->size >=size) // node is free and > = req size
nsize=node->size;
update_node(node,size+csize);
if(nsize>size) //node > req size, so split and add new node to memlist
new=create_node(nsize-size-sizeof(node_t),(long)node+sizeof(node_t)+size);
insert_node_after(node,new);
}//end if
}//end if
node=node->next;
}//end while
if(node==NULL)// reached end without finding an appropriate node
//printf("\r\n Not enough memory for allocation");
return NULL;
return (char *)node+sizeof(node_t); // return pointer to allocated space
The condition is the if statement in bold is never true, so the malloc function just keep looping node after node.
What's going on? |
Posted: Fri Nov 26, 2004 3:58 am |
| Quote: | | Someone from CCS, I need to know... | This is a user's forum, so basically who you will find here are other users like you. Which doesn't mean that we won't try to help you.
| Quote: | | The condition is the if statement in bold is never true, so the malloc function just keep looping node after node. | So this means all the nodes are in use, which is possible. Then at the end of the node list it exits the while loop and malloc() returns NULL. You say malloc never returns... That's strange and I can hardly believe it. Are you sure this is really what's happening?
Please post a small test program so we can verify your conclusions.
A few other remarks:
- When posting code, please use the 'Code' button, this makes sure the layout of your code is preserved.
- When reporting problems always report the compiler version and processor type you are using. |
Posted: Fri Nov 26, 2004 8:48 am |
I am pretty sure that malloc never returns. I simulated my program using MPLAB, and the malloc function just keeps looping.
What really sucks is that when I write a small test small program, malloc works somehow. But Malloc is unable to allocate 41 bytes in my larger program.
That's why I wanted to know a little bit more about __DYNAMIC_HEAD.
Maybe my larger program has an influence on it. |
Posted: Fri Nov 26, 2004 9:58 am |
Here is some code.
The code that calls malloc is:
| Code: | void *pvReturn;
pvReturn = malloc( usWantedSize ); |
At this point, usWantedSize contains the value 0x29, which is 41 in decimal.
Now, when the malloc function is called:
| Code: | char *malloc([b]size_t size[/b])
node_t *node,*new;
long nsize;
if[u](!bit_test(node->size,pos)
&& node->size >=[b]size[/b]) [/u]// node is free and > = req size
nsize=node->size;
}//end if
}//end if
node=node->next;
}//end while
return NULL;
The value of size is 0x0A29 instead of of 0x29. This is why the condition in 'if' statement node->size >=size is never true.
So the function keeps looping.
Can someone tell me why I pass 0x29 to the function, and the function gets the value 0x0A29 ???? |
Posted: Fri Nov 26, 2004 10:37 am |
I Found the solution to my problem.
I chaged the definition of size_t in <stddef.h>
from #define size_t int
to #define size_t long
my memory allocation is working fine now. |
