alexz
Not zero constant |
Posted: Wed Nov 24, 2004 5:53 am |
Is there a way to define a not zero constant?
Something like:
#define CONST_NAME !0
Thank you _________________ Alex |
Posted: Wed Nov 24, 2004 6:40 am |
Code: | #define CONST_NAME !0
#define CONST_NAME2 ~0
int8 a, b;
int16 c;
a = CONST_NAME; // a = 0x01
b = CONST_NAME2; // b = 0xFF
c = CONST_NAME2; // c = 0x00FF
alexz
Posted: Wed Nov 24, 2004 6:47 am |
ckielstra wrote: | Code: | #define CONST_NAME !0
int8 a, b;
int16 c;
is the CONST_NAME always '1'?
what about all others except zero? _________________ Alex |
Mark
Posted: Wed Nov 24, 2004 7:15 am |
Quote: | Is there a way to define a not zero constant?
Maybe you should explain how you want to use it so that it will be more clear to us what you are trying to do. |
Re: Not zero constant |
Posted: Wed Nov 24, 2004 10:49 am |
alexz wrote: | Is there a way to define a not zero constant?
Something like:
Thank you |
Firstly, what you show here, is a macro, not a 'constant'. A macro, is just an instruction to the compiler to substitute the right hand text, where the 'name' is given. As such, it has some really major 'caveats'. If (for instance), you define a macro as shown, then code:
X = CONST_NAME*2;
This will be converted to:
X = !0*2;
Now the result will depend on the arithmetic precedence. '*', fortunately has a lower precedence than the 'not' operator, so the result will be as expected, but it is the cause of many unexpected results when using macro expansions like this. Hence it is always safer to 'bracket' the right hand term, which forces the entire 'assembly' to have a higher precedence.
If you want a 'non zero constant', the normal method, would be:
const int8 non_zero = !0;
Which will store a constant 8 bit integer, containing the logical 'not' of '0'.
That macros are not 'constants', can easily be demonstrated, by having a second #define, and changing the value.
