pls give me some suggestion about converting this to 16f877
Goto page 1, 2  Next
saroch
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sun Nov 21, 2004 9:55 am     Reply with quote
Here is the code that i recieved form Mark and i wanna change this code for 16f877.
but when i try to change, so many problems have occured.
pls give me some suggestion to convert that code for 16f877.
thx everyone in advance
saroch
PostPosted: Sun Nov 21, 2004 9:56 am     Reply with quote
oh forgot the code
/*            RTTTL Ring Tone Player for Microchip Microcontrollers          */
/* This program was designed to run on the PICDEM2 Plus demo board from      */
/* Microchip.        */
/* Usage:        */
/*         S3 - Selects Melody                                               */
/*         S2 - Starts/Stops Melody                                          */
/* This code was designed for a clock speed of 20MHz                         */
/* The target device was a PIC18F452.                                        */
/* You can use the PIC16F877 by changing the setup of CCP1 to                */
/* CCP_COMPARE_INT.  You will also need to toggle the output pin in the      */
/* CCP1 interrupt routine.                                                   */
/* Many of the tunes were downloaded from "www.mrtones.com"                  */
#case
#list
#include "18F452.h"
#device *=16
#define CLOCKSPEED     20000000
#define CCP_COMPARE_TOGGLE_MATCH        2
#use delay(CLOCK=CLOCKSPEED)
#fuses HS, NOWDT, NOLVP, PUT
// Include this file after our #use delay
#include "lcd.c"
#define TMR1_PRESCALE  8
#define NOTE_C_SHARP   (((CLOCKSPEED/4)/277.18)/TMR1_PRESCALE)            // 277.18Hz
#define NOTE_D_SHARP   (((CLOCKSPEED/4)/311.13)/TMR1_PRESCALE)            // 311.13 Hz
#define NOTE_F_SHARP   (((CLOCKSPEED/4)/369.99)/TMR1_PRESCALE)            // 369.99 Hz
#define NOTE_G_SHARP   (((CLOCKSPEED/4)/415.30)/TMR1_PRESCALE)            // 415.30 Hz
#define NOTE_A_SHARP   (((CLOCKSPEED/4)/466.16)/TMR1_PRESCALE)            // 466.16 Hz
#define NOTE_C         (((CLOCKSPEED/4)/261.63)/TMR1_PRESCALE)            // 261.63 Hz
#define NOTE_D         (((CLOCKSPEED/4)/293.66)/TMR1_PRESCALE)            // 293.66 Hz
#define NOTE_E         (((CLOCKSPEED/4)/329.63)/TMR1_PRESCALE)            // 329.63 Hz
#define NOTE_F         (((CLOCKSPEED/4)/349.23)/TMR1_PRESCALE)            // 349.23 Hz
#define NOTE_G         (((CLOCKSPEED/4)/392.00)/TMR1_PRESCALE)            // 392.00 Hz
#define NOTE_A         (((CLOCKSPEED/4)/440.00)/TMR1_PRESCALE)            // 440.00 Hz
#define NOTE_B         (((CLOCKSPEED/4)/493.88)/TMR1_PRESCALE)            // 493.88 Hz
#define NOTE_SILENCE   0
#define DURATION_32   5    // Duration = 2^x
#define DURATION_16   4    // Duration = 2^x
#define DURATION_8    3    // Duration = 2^x
#define DURATION_4    2    // Duration = 2^x
#define DURATION_2    1    // Duration = 2^x
#define DURATION_1    0    // Duration = 2^x
typedef enum
  SILENTNIGHT,
  JINGLEBELLS,
  LAST_MELODY
}MELODIES;
typedef struct
  int Head;
  int Tail;
  int Count;
} NOTESTAT;
typedef struct
  long note;
  long duration;
}NOTE_DEF;
struct
  int TRISC0:1;
  int TRISC1:1;
  int TRISC2:1;
  int TRISC3:1;
  int TRISC4:1;
  int TRISC5:1;
  int TRISC6:1;
  int TRISC7:1;
}TRISCbits;
#locate TRISCbits = 0xF94
long TMR1;
#locate TMR1 = 0xFCE
int TMR1L;
#locate TMR1L = 0xFCE
int TMR1H;
#locate TMR1H = 0xFCF
int TMR0;
#locate TMR0 = 0xFD6
#define   MAX_NOTE_BUFFER_SIZE  4
#define   NOTE_ROLLOVER_MASK     0b00000011
NOTE_DEF  NoteBuffer[MAX_NOTE_BUFFER_SIZE];
NOTESTAT  Notestat = {0,0,0};
long      DurationCount=0;
int       Tempo=0;
long      Note_Ticks=0;
MELODIES  Melody_Pointer;
long      Note_Index = 0xFFFF;
BOOLEAN   PlayMelodyFlag = TRUE;
int       Read_Button_Count = 0;
const struct
  char tune[192];
  int  defaultoctave;
  int  defaultduration;
  int  tempo;
}SilentNight = {
                 {"f#.,8g#,f#,d#.,p.,f#.,8g#,f#,d#.,p.,2c#6,c#6,a#.,p.,2b,b,f#.,p.,2g#,g#,b.,8a#,g#,f#.,8g#,f#,d#.,p.,2g#,g#,b.,8a#,g#,f#.,8g#,f#,d#.,p.,2c#6,c#6,e.6,8c#6,a#,2b.,2d#6,p.,b,f#,d#,f#.,8e,c#,b.4,1p"},
                 5,
                 DURATION_4,
                 140
const struct
  char tune[202];
  int  defaultoctave;
  int  tempo;
}JingleBells = {
                 {"8e.,8e.,e.,8e.,8e.,e.,8e.,8g.,c,16d.,2e,p,8f.,8f.,f,16f.,8f.,8e.,8e.,16e.,16e.,8e.,8d.,8d.,8e.,d.,g.,8e.,8e.,e.,8e.,8e.,e.,8e.,8g.,c,16d.,2e,p,8f.,8f.,f,16f.,8f.,8e.,8e.,16e.,16e.,8g.,8g.,8f.,8d.,c.,1p"},
                 5,
                 DURATION_4,
                 180
/* Function Prototypes */
void InitTimer(void);
int PlayMelody();
void PlayNote(long note, int octave, int duration);
char get_char_from_tune(long index);
int get_tempo(void);
int get_defaultoctave(void);
int get_defaultduration(void);
void display_melody_name(void);
void Melody_Task(void);
void Button_Task(void);
void Check_Button_Press(void);
// Start of Code
  DESCRIPTION:  This function handles checking for button presses
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  TRISCbits.TRISC2 = 0;
  InitTimer();
  lcd_init();
  Melody_Pointer = JINGLEBELLS;
  display_melody_name();
    Button_Task();
    Melody_Task();
  DESCRIPTION:  This function handles the playing of a melody
  RETURN:       True if the melody is still active or False if its complete
  ALGORITHM:    none
  NOTES:        none
int PlayMelody(void)
  int octave = 0;
  int duration = 0;
  long note = 0;
  // Check for a valid Melody
  if (Melody_Pointer >= LAST_MELODY)
    // Reset the Melody to the start
    Melody_Pointer = 0;
  // Load notes while we have enough room
  while (Notestat.Count < MAX_NOTE_BUFFER_SIZE)
    // Is this the first note?
    if (Note_Index == 0xFFFF)
      Tempo = get_tempo();
      Note_Index = 0;
    // Set Default duration
    duration = get_defaultduration();
    // Set Default Octave
    octave = get_defaultoctave();
    // Play a bit of slience between notes
    if (get_char_from_tune(Note_Index) == ',')
      PlayNote(0, 4, DURATION_32);
      Note_Index++;
      return(TRUE);
    // We are checking the duration
    else if ((get_char_from_tune(Note_Index) == '3') && (get_char_from_tune(Note_Index+1) == '2'))
      duration = DURATION_32;
      Note_Index += 2;
    else if ((get_char_from_tune(Note_Index) == '1') && (get_char_from_tune(Note_Index+1) == '6'))
      duration = DURATION_16;
      Note_Index += 2;
    else if (get_char_from_tune(Note_Index) == '8')
      duration = DURATION_8;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '4')
      duration = DURATION_4;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '2')
      duration = DURATION_2;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '1')
      duration = DURATION_1;
      Note_Index++;
    // Now we get the note
    switch (get_char_from_tune(Note_Index++))
      case 'c':
        if (get_char_from_tune(Note_Index) == '#')
          note = NOTE_C_SHARP;
          Note_Index++;
          note = NOTE_C;
      case 'd':
          note = NOTE_D_SHARP;
          Note_Index++;
          note = NOTE_D;
      case 'e':
        note = NOTE_E;
      case 'f':
          note = NOTE_F_SHARP;
          Note_Index++;
          note = NOTE_F;
      case 'g':
          note = NOTE_G_SHARP;
          Note_Index++;
          note = NOTE_G;
      case 'a':
          note = NOTE_A_SHARP;
          Note_Index++;
          note = NOTE_A;
      case 'b':
        note = NOTE_B;
      case 'p': // slience
        note = NOTE_SILENCE;
    // See if this note is 1.5x the duration
    if (get_char_from_tune(Note_Index) == '.')
      // Use the MSB to signify 1.5x
      duration |= 0x80;
      Note_Index++;
    // Get the octave
    switch (get_char_from_tune(Note_Index))
      case '4':
        octave = 4;
        Note_Index++;
      case '5':
        octave = 5;
        Note_Index++;
      case '6':
        octave = 6;
        Note_Index++;
      case '7':
        octave = 7;
        Note_Index++;
      default:
    // Sometimes the duration multiplier comes after the octave
      /* Duration 1.5x */
      duration |= 0x80;
      Note_Index++;
    // Play the note (we actually just load it in a buffer
    PlayNote(note, octave, duration);
    // Is this the end?
    if (get_char_from_tune(Note_Index) == 0)
      return(FALSE);
    return(TRUE);
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  long duration_count;
  // Process octave
  switch (octave)
    case 4 :
    case 5 :
      note = note >> 1;
    case 6 :
      note = note >> 2;
    case 7 :
      note = note >> 4;
  // Process Note Duration
  duration_count = 256;
  duration_count >>= (duration & 0x7F);
  // If duration is 1.5x add .5 to duration
  if (duration & 0x80)
    duration_count += (duration_count >> 1);
  // Add the note to our buffer
  NoteBuffer[Notestat.Tail].note = note;
  NoteBuffer[Notestat.Tail].duration = duration_count;
  Notestat.Tail++;
  Notestat.Tail &= NOTE_ROLLOVER_MASK;
  Notestat.Count++;
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  setup_timer_0(RTCC_DIV_256 | RTCC_8_BIT);
  setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
  setup_timer_2(T2_DIV_BY_4, 250, 5);
  enable_interrupts(INT_CCP1);
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  switch (Melody_Pointer)
    case SILENTNIGHT:
      return (SilentNight.tune[index]);
    case JINGLEBELLS:
      return (JingleBells.tune[index]);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
int get_tempo(void)
    case SILENTNIGHT:
      return (SilentNight.tempo);
    case JINGLEBELLS:
      return (JingleBells.tempo);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
    case SILENTNIGHT:
      return (SilentNight.defaultoctave);
    case JINGLEBELLS:
      return (JingleBells.defaultoctave);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
    case SILENTNIGHT:
      return (SilentNight.defaultduration);
    case JINGLEBELLS:
      return (JingleBells.defaultduration);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  if (PlayMelodyFlag)
    if (!PlayMelody())
      Melody_Pointer++;
  DESCRIPTION:  This function displays the title of the melody on the LCD
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  // Clear the screen and make sure that we are at the top
  lcd_putc("\f");
  lcd_gotoxy(0,1);
  // Use our global Melody_Pointer to determine the title of the current tune
    case SILENTNIGHT:
      lcd_putc("Silent Night");
    case JINGLEBELLS:
      lcd_putc("JingleBells");
     default:
  DESCRIPTION:  Button Tasks
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  if (!Read_Button_Count)
    Read_Button_Count = 30;
    Check_Button_Press();
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  static int debounce_count = 4;
  static int stable = 0xFF;
  static int last = 0xFF;
  int trans_low;
  int current = 0xFF;
  BOOLEAN change = FALSE;
  // Read the current state of the buttons
  if (!input(PIN_A4))
    bit_clear(current,2);
  if (!input(PIN_B0))
    bit_clear(current,3);
  // See if they have changed
  if (current != last)
    last = current;
    change = TRUE;
  // If they have changed then reset our counter
  if (change)
    debounce_count = 4;
  // Each time they are stable, then decrement our count
  else if (debounce_count)
    debounce_count--;
  // They have been stable long enough so act on them
  else if (current != stable)
    // Get the high transitions
    trans_low = ((stable ^ current) & stable);
    if (bit_test(trans_low,2))
      PlayMelodyFlag = ! PlayMelodyFlag;
    if (bit_test(trans_low,3))
      Melody_Pointer++;
        Melody_Pointer = 0;
    stable = current;
// ISR routines
#int_ccp1
  DESCRIPTION:  This function controls the PWM of the piezo speaker
  RETURN:       none
  ALGORITHM:    none
  NOTES:  If you do not wish to use C2 as the output, then you will need
          to toggle your output here.  Make sure that you change the CCP
          setup not to toggle the C2 output if this is the case
void ccp1_isr (void)
  CCP_1 += Note_Ticks;
  DESCRIPTION:  This function is used to control the duration of the note
  RETURN:       none
  ALGORITHM:    none
  NOTES:  I store the notes in a buffer so that the main loop has other
          time to do stuff with out have to sit at wait for a note to
          complete.
#int_timer0
void timer0_isr (void)
  // Preload a value for TMR0 so that we can control how long it takes to
  // trigger an interrupt
  TMR0 = Tempo;
  // Is a note playing?
  if (DurationCount)
    DurationCount--;
    if (!DurationCount)
      setup_ccp1(CCP_OFF);
  // Note is finished playing, do we have anymore in our buffer?
  else if (Notestat.Count)
    DurationCount = NoteBuffer[Notestat.Head].duration;
    Note_Ticks = NoteBuffer[Notestat.Head].note;
    Notestat.Count--;
    Notestat.Head++;
    Notestat.Head &= NOTE_ROLLOVER_MASK;
    CCP_1 = TMR1 + Note_Ticks;
    if (Note_Ticks)
      /* Setup the CCP module to toggle the output pin c2 */
      setup_ccp1(CCP_COMPARE_TOGGLE_MATCH);
    // Nope, we are all through so disable the PWM
#int_timer2
  DESCRIPTION:  This function is our system tick set at 1ms
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
void timer2_isr (void)
  if (Read_Button_Count)
    Read_Button_Count--;
saroch
PostPosted: Sun Nov 21, 2004 9:57 am     Reply with quote
oh forgot the code
/* Microchip. */
/* Usage: */
#case
#list
#include "18F452.h"
#device *=16
#include "lcd.c"
typedef enum
SILENTNIGHT,
JINGLEBELLS,
LAST_MELODY
}MELODIES;
typedef struct
int Head;
int Tail;
int Count;
} NOTESTAT;
typedef struct
long note;
long duration;
}NOTE_DEF;
struct
int TRISC0:1;
int TRISC1:1;
int TRISC2:1;
int TRISC3:1;
int TRISC4:1;
int TRISC5:1;
int TRISC6:1;
int TRISC7:1;
}TRISCbits;
long TMR1;
int TMR1L;
int TMR1H;
int TMR0;
int Tempo=0;
long Note_Ticks=0;
const struct
char tune[192];
int defaultoctave;
int tempo;
}SilentNight = {
5,
DURATION_4,
140
const struct
char tune[202];
int defaultoctave;
int tempo;
}JingleBells = {
5,
DURATION_4,
180
int PlayMelody();
// Start of Code
RETURN: none
ALGORITHM: none
NOTES: none
InitTimer();
lcd_init();
Button_Task();
Melody_Task();
ALGORITHM: none
NOTES: none
int octave = 0;
int duration = 0;
long note = 0;
Melody_Pointer = 0;
Note_Index = 0;
Note_Index++;
return(TRUE);
Note_Index += 2;
Note_Index += 2;
Note_Index++;
Note_Index++;
Note_Index++;
Note_Index++;
case 'c':
Note_Index++;
note = NOTE_C;
case 'd':
Note_Index++;
note = NOTE_D;
case 'e':
note = NOTE_E;
case 'f':
Note_Index++;
note = NOTE_F;
case 'g':
Note_Index++;
note = NOTE_G;
case 'a':
Note_Index++;
note = NOTE_A;
case 'b':
note = NOTE_B;
duration |= 0x80;
Note_Index++;
// Get the octave
case '4':
octave = 4;
Note_Index++;
case '5':
octave = 5;
Note_Index++;
case '6':
octave = 6;
Note_Index++;
case '7':
octave = 7;
Note_Index++;
default:
/* Duration 1.5x */
duration |= 0x80;
Note_Index++;
// Is this the end?
return(FALSE);
return(TRUE);
RETURN: none
ALGORITHM: none
NOTES: none
// Process octave
switch (octave)
case 4 :
case 5 :
note = note >> 1;
case 6 :
note = note >> 2;
case 7 :
note = note >> 4;
Notestat.Tail++;
Notestat.Count++;
RETURN: none
ALGORITHM: none
NOTES: none
RETURN: none
ALGORITHM: none
NOTES: none
case SILENTNIGHT:
case JINGLEBELLS:
default:
RETURN: none
ALGORITHM: none
NOTES: none
int get_tempo(void)
case SILENTNIGHT:
case JINGLEBELLS:
default:
RETURN: none
ALGORITHM: none
NOTES: none
case SILENTNIGHT:
case JINGLEBELLS:
default:
RETURN: none
ALGORITHM: none
NOTES: none
case SILENTNIGHT:
case JINGLEBELLS:
default:
RETURN: none
ALGORITHM: none
NOTES: none
if (PlayMelodyFlag)
if (!PlayMelody())
Melody_Pointer++;
RETURN: none
ALGORITHM: none
NOTES: none
lcd_putc("\f");
lcd_gotoxy(0,1);
case SILENTNIGHT:
case JINGLEBELLS:
default:
RETURN: none
ALGORITHM: none
NOTES: none
RETURN: none
ALGORITHM: none
NOTES: none
int trans_low;
int current = 0xFF;
if (!input(PIN_A4))
if (!input(PIN_B0))
last = current;
change = TRUE;
if (change)
debounce_count = 4;
debounce_count--;
Melody_Pointer++;
Melody_Pointer = 0;
stable = current;
// ISR routines
#int_ccp1
RETURN: none
ALGORITHM: none
RETURN: none
ALGORITHM: none
complete.
#int_timer0
TMR0 = Tempo;
if (DurationCount)
DurationCount--;
if (!DurationCount)
Notestat.Count--;
Notestat.Head++;
if (Note_Ticks)
#int_timer2
RETURN: none
ALGORITHM: none
NOTES: none
Mark
PostPosted: Sun Nov 21, 2004 2:08 pm     Reply with quote
What sort of problems did you have and what did you do to try and change it? I am not at home right now but I will look at it later. I thought I listed what needed to be done to change it but its been about a year since I did it.
Mark
PostPosted: Sun Nov 21, 2004 9:19 pm     Reply with quote
Posted new code Below
PostPosted: Sun Nov 21, 2004 9:47 pm     Reply with quote
If I don't want to use PICDEM2+ board, what is the circuit of this code?
thx
Mark
PostPosted: Sun Nov 21, 2004 10:30 pm     Reply with quote
Here is the schematic:
http://ww1.microchip.com/downloads/en/DeviceDoc/51275b.pdf
saroch
PostPosted: Mon Nov 22, 2004 8:08 am     Reply with quote
Hi, Mark
I made a little change to your code.
So I don't worry about pushing button.
  InitTimer();
  lcd_init();
    //Button_Task();
    Melody_Task();
And I connect PIN17 (RC2/CCP1) to the speaker and grounded it.
But I still don't hear the sound !!!
pls help
thanks
Mark
PostPosted: Mon Nov 22, 2004 8:18 am     Reply with quote
What kind of speaker?
I think maybe you should just write a simple program to toggle pin_c2 and a few hundred Hz and see if you hear anything
#include <16F877.h>
#device *=16
#case
#ZERO_RAM
//======================= MAIN ============================//
void main(void
    // Generate an 800Hz tone
    output_toggle(PIN_C2);
    delay_us(625);
saroch
PostPosted: Mon Nov 22, 2004 11:02 am     Reply with quote
Hi, Mark
I try to make my new simple program based on your code.
Here is my code
#include <16F877.h>
#use delay(clock=CLOCKSPEED)
#define PRESCALE       16
#define N_C         (((CLOCKSPEED/4)/1661.63)/PRESCALE)-1         //187.07
#define N_D         (((CLOCKSPEED/4)/1893.66)/PRESCALE)-1         //164.02
#define N_E         (((CLOCKSPEED/4)/2229.63)/PRESCALE)-1         //139.16
   char mysong[6]={'C','E','C','E','D','E'};
   char note;
   int i,j;
   setup_ccp1(CCP_PWM);
   while( TRUE )
      for (i=0;i<5;i++)
         note=mysong[i];
         switch (note)
         case 'C' :
               for (j=1;j<500;j++)
               setup_timer_2(T2_DIV_BY_16, 255, 1);
               set_pwm1_duty(376.25);
         case 'D' :
               for (j=1;j<500;j++)
               setup_timer_2(T2_DIV_BY_16, N_D, 1);
               set_pwm1_duty(330.05);
               delay_ms(1);
         case 'E' :
               for (j=1;j<500;j++)
               setup_timer_2(T2_DIV_BY_16, 40, 1);
               set_pwm1_duty(280.32);
               delay_ms(1);
Any number is unreasoned assumed.
BUT when I burn to PIC, I can hear only one long sound and never change to another frequency.
I think I stuck on the infinity loop.
pls help me correct that code
thx (again)
PostPosted: Mon Nov 22, 2004 11:24 am     Reply with quote
for (j=1;j<500;j++)
J is defined as an 8-bit integer and results in an infinite loop. Change to 16 bit.
Also:
This gives you a single sound of 25 seconds....
and:
Syntax:
set_pwm1_duty (value)
set_pwm2_duty (value)
Parameters: value may be an 8 or 16 bit constant or variable.
Your parameter is not an integer...
Mark
PostPosted: Mon Nov 22, 2004 11:34 am     Reply with quote
How can you have a float for a value? Not possible.
The little test program that I posted should generate a sound. That is what I am interested in. It proves that the speaker is connected and WILL produce sound. Does the LCD work or do you even have an LCD connected?
saroch
PostPosted: Mon Nov 22, 2004 11:51 am     Reply with quote
ckielstra,
Why 25 sec
It is 0.5 sec, isn't it?
Mark,
I think that my speaker will have a problem and I didn't connect LCD also.
BIG THANKS TO BOTH OF YOU
Mark
PostPosted: Mon Nov 22, 2004 11:53 am     Reply with quote
You have the delay_ms(500) inside a loop of 500 so it is actually 250 seconds.
PostPosted: Mon Nov 22, 2004 12:00 pm     Reply with quote
Ooops. Embarassed
Goto page 1, 2  Next
Page 1 of 2
