Not zero constant
alexz
Not zero constant
PostPosted: Wed Nov 24, 2004 5:53 am     Reply with quote
Is there a way to define a not zero constant?
Something like:
#define CONST_NAME !0
Thank you
Alex
PostPosted: Wed Nov 24, 2004 6:40 am     Reply with quote
#define CONST_NAME2 ~0
  int8 a, b;
  int16 c;
  a = CONST_NAME;      // a = 0x01
  b = CONST_NAME2;     // b = 0xFF
  c = CONST_NAME2;     // c = 0x00FF
alexz
PostPosted: Wed Nov 24, 2004 6:47 am     Reply with quote
  int8 a, b;
  int16 c;
is the CONST_NAME always '1'?
what about all others except zero?
Alex
Mark
PostPosted: Wed Nov 24, 2004 7:15 am     Reply with quote
Maybe you should explain how you want to use it so that it will be more clear to us what you are trying to do.
Re: Not zero constant
PostPosted: Wed Nov 24, 2004 10:49 am     Reply with quote
Something like:
Thank you
Firstly, what you show here, is a macro, not a 'constant'. A macro, is just an instruction to the compiler to substitute the right hand text, where the 'name' is given. As such, it has some really major 'caveats'. If (for instance), you define a macro as shown, then code:
X = CONST_NAME*2;
This will be converted to:
X = !0*2;
Now the result will depend on the arithmetic precedence. '*', fortunately has a lower precedence than the 'not' operator, so the result will be as expected, but it is the cause of many unexpected results when using macro expansions like this. Hence it is always safer to 'bracket' the right hand term, which forces the entire 'assembly' to have a higher precedence.
If you want a 'non zero constant', the normal method, would be:
const int8 non_zero = !0;
Which will store a constant 8 bit integer, containing the logical 'not' of '0'.
That macros are not 'constants', can easily be demonstrated, by having a second #define, and changing the value.
