porting CCS Bootloader Sample to 18F2620
Stefan
PostPosted: Thu Nov 18, 2004 4:00 pm     Reply with quote
Hi there,
what do I have to change on ex_bootloader.c, loader.c or ex_bootxx.h to use with 18F2620.
With 18F252 it works my code but I dont know to get it work with my new PIC 18F2620.
thanks for help
Stefan
Boyko
PostPosted: Fri Nov 19, 2004 1:15 pm     Reply with quote
Try the Colt 18F bootloader. It's nice, free and works with all 18F chips.
Regards
Boyko
PostPosted: Sun Nov 21, 2004 7:11 am     Reply with quote
Thanks had a look to colt bootloader but the problem is I have to change some code to work with my one circuit.
But I found mybe there is a problem in write_program_memory(..).
Thy write different for 18F252 to 18F2620 in the capt.
FLASH PROGRAM MEMORY WRITE SEQUENCE
18F252 :
6. Write the first 8 bytes into the holding registers
with auto-increment.
18F2620:
6. Write the 64 bytes into the holding registers with
Note: Before setting the WR bit, the Table
Pointer address needs to be within the
intended address range of the 64 bytes in
the holding register.
I use PCH Compiler V. 3.212 and does the compiler do that ??
Stefan
