harry_bach
Joined: 20 Nov 2004 Posts: 2 Location: Edinburgh, Scotland
incorporating two interrupts (rda and ext) |
Posted: Sat Nov 20, 2004 12:10 pm |
I have a problem incorporating two interrupts (rda and ext) on the PIC18F452. I have an application that transmits data from flash to a server using xmodem via a mobile phone. This is working fine, but yesterday I added a simple trigger for this process using the external interupt ext. I find that when I add the ISR for the external interupt the serial interrupt stops working. When I break the code it appears the GIE (INTCON.7) is set to 0, but I cannot find where this occurs. Interestingly PEIE remains set. Its as if its already inside an ISR ? I have included snippets of code below.
Could someone point out what I am doing wrong please ?
I guess my real problem is I don't really understand when to use enable_interrupts(global) if I am switching on and off the rda enable bit (PIE.5) through the code. Is it each time I change the bit or only once at the beginning.
Code: | void main()
initialise();
do
//sleep();
MakeThatCall();
} while (status != ERROR);
IndicateError();
//******************************** PIC ***********************************
#int_rda
void serial_isr(void)
TempBuffer=getc();
if ((TempBuffer!=CR)&&(TempBuffer!=LF)&&(TempBuffer!=SP))
*RxBufferTop++=TempBuffer;
if (RxBufferTop>(RxBuffer+BUFFER_SIZE))
RxBufferTop=RxBuffer; // Reset pointer
#int_ext
void PermissionToSend_isr(void)
/* if (INTEDG0) // if detected edge is rising
FlashYellowLedFast(2); // testing !!!!!!!!!!!!
Reset_CPU();
delay_cycles(1);
int8 EnableRegistration()
int8 i;
for(i=0; i<10; i++)
delay_ms(150);
FlushRS232();
ClearBuffer();
SERIAL_ON;
GLOBAL_INTERUPTS;
printf("AT+COPS=0\r\n");
if (WaitModemResponseOKLong())
return TRUE;
return FALSE;
int8 WaitModemResponseOKLong()
// Waits for each tick period and examines the RxBuffer for 'OK'
// If a timeout occurs status set to error
WaitCounter=0;
do
delay_ms(TICK);
if(WaitCounter++>AWAIT_OK_LONG)
status = ERROR;
return FALSE;
if(strstr(RxBuffer, ERRORR))
return FALSE;
} while(!(strstr(RxBuffer, OK)));
SERIAL_OFF;
GLOBAL_INTERUPTS;
return TRUE;
_________________ Harry. |
Posted: Sat Nov 20, 2004 3:32 pm |
I don't think you gave enough information yet.
You need to post your #use rs232() statement.
It wouldn't hurt to post your #use delay() and
#fuses statements, too.
Also post the lines where you define these macros:
SERIAL_ON;
SERIAL_OFF;
GLOBAL_INTERUPTS;
If they have #bit or #byte statements in them,
then post those too. |
harry_bach
Posted: Sun Nov 21, 2004 1:32 pm |
Just to explain further MakeThatCall() uses a series of sub-functions including EnableRegistration(). All these sub functions follow the same pattern sending an AT command and await a response using functions like WaitModemResponseOKLong(), which compare a fixed string responds with an RxBuffer which in turn is filled by the RDA ISR. The code works in its current form, but if I add any code in the int_ext ISR the GIE bit sets to 0 somewhere and so when serial data is received the serial ISR is not called (even with the enable_interrupts(INT_EXT) commented out in the initialise() function.
Code: | #use delay(clock=4000000)
#fuses XT,NOWDT,WDT1
#use RS232 (baud=9600, xmit=PIN_C6, RCV=PIN_C7, bits=8, ERRORS)
#use i2c (master)
#define GLOBAL_INTERUPTS enable_interrupts(global)
#define SERIAL_ON enable_interrupts(int_rda)
#define SERIAL_OFF disable_interrupts(int_rda)
void initialise(void)
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
MODEM_OFF;
//PD_FLOAT; // need PD to float or as input on old board 4.3 phone board
PD_LOW; // Need to set PD as an O/P on the daughter board
status=IDLE;
FlashLedFast(2);
//ext_int_edge(0, H_TO_L); // Set edge to trigger on
//enable_interrupts(INT_EXT);
//enable_interrupts(GLOBAL);
Posted: Sun Nov 21, 2004 4:48 pm |
A few comments:
1. You should have NOLVP in your #fuses statement. Without that,
you risk having random lock-ups.
2. I'm not sure why you have WDT1 in your #fuses statement.
I would have only NOWDT during the debugging process.
3. I don't know why you want to shut off RS-232 interrupts periodically.
I would just let them run. You have a circular buffer to receive
the characters. If you're not going to check the buffer for a long
time, then perhaps set a global flag if the buffer overflows.
Or perhaps just clear the buffer, before you go to use it again.
4. I would enable interrupts for INT_RDA and GLOBAL once, near the
start of the program, in main().
5. You have this line:
It compiles without error, but you should specify the SDA and SCL pins.
Without those pins, it looks to me like the compiler is generating semi-garbage code and that's not good.
6. I'm not sure what the purpose of you INT_EXT routine is:
Code: | #int_ext
Reset_CPU();
delay_cycles(1);
So if you get an external interrupt, you want to reset the CPU ?
What's the definition of 'INTEDG0' ?
I wonder if the CPU is getting reset at a time when you don't intend it to ?
Your basic complaint is that INT_RDA stops when you "add code" to the
INT_EXT routine. Well, adding code that resets the CPU on some edge
(or noise on the pin), is not my idea of a good test.
I would strip out everything in that routine except the delay_cycles(1)
and see if your problem goes away. |
