angel
best combination USART : speed, quartz and PIC 16F87x |
Posted: Fri Nov 19, 2004 6:07 am |
Hi
I noticed that using different type of quartz and different USART speed the USART behaviour is different. Exemple : printf function depends of this selection.
Does anyone know the best combination Usart Speed, quart for a PIC 16F87x using CCS? |
Re: best combination USART : speed, quartz and PIC 16F87x |
Posted: Fri Nov 19, 2004 7:37 am |
angel wrote: | Hi
Have a look at the MicroChip data sheet for the chip. Note especially the section in table 10-3, showing baud rate errors for some typical clock rates. The 'best', will depend on how fast you want to run the chip, and what baud rates you want, but probably (getting as close to 20MHz as possible), 18.432MHz. The 'key', is that this is a direct binary multiple of most common rates (it is 5* the 3.6864MHz rate used by MicroChip to show the effectiveness of this approach), and is a common crystal for baud rate applications for exactly this reason.
