OPAMP
Testadura
OPAMP
PostPosted: Fri Nov 12, 2004 8:48 am     Reply with quote
Somebody has experience with OPAMP ?
CCS not support OPAMP
Mark
PostPosted: Fri Nov 12, 2004 9:33 am     Reply with quote
Well if you are talking about a general purpose OP-AMP then there is nothing to support! They typically only have passive components such as resistors and capacitors connected to them to make them "do" something.
Testadura
PostPosted: Fri Nov 12, 2004 10:22 am     Reply with quote
I am talking about OpAmp in the micro.
Somebody has code example for this peripheral ?
Mark
PostPosted: Fri Nov 12, 2004 10:23 am     Reply with quote
Comparator??
Testadura
PostPosted: Fri Nov 12, 2004 10:27 am     Reply with quote
In the PIC16C781 existes an Operational Amplifier
Mark
PostPosted: Fri Nov 12, 2004 11:05 am     Reply with quote
What are you trying to do?
#define OPAMP_ON            0b10000000
#define OPAMP_OFF           0b00000000
#define FAST_MODE           0b00000001
#define SLOW_MODE           0b00000000
#byte OPACON = 0x11C
#byte CALCON = 0x110
#byte DAC    = 0x11E
#byte DACON0 = 0x11F
#define setup_opamp(x) OPACON = x
BOOLEAN calibrate_opamp_internal(void)
  // Turn on the opamp 2MHz GBWP
  OPACON = OPAMP_ON | FAST_MODE;
  // Set reference to 1.2V
  bit_clear(CALCON, 5);
  // Start the calibration
  bit_set(CALCON, 7);
  // Wait on the calibration
  while( bit_test(CALCON, 7) );
  // Check for an error
  if (bit_test(CALCON, 6))
    return(false);
    return(true);
BOOLEAN calibrate_opamp_dac(int value)
  // Set reference to DAC
  bit_set(CALCON, 5);
  // Set the DAC voltage
  DAC = value;
  // Enable DAC
  DACON0 = 0b10000000;
  bit_set(CALCON, 7);
    return(false);
    return(true);
rwyoung
PostPosted: Fri Nov 12, 2004 3:05 pm     Reply with quote
Microchip's AN823 has loads of good aplication information for the C78x parts.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
JK
Try
PostPosted: Sat Nov 13, 2004 11:59 am     Reply with quote
Try use external MSP6S2X by Micrichip.
Testadura
PostPosted: Mon Nov 15, 2004 3:10 am     Reply with quote
OK
I'am starting to work with your helping
Testadura
PostPosted: Mon Nov 15, 2004 7:41 am     Reply with quote
Delete me
Testadura
PostPosted: Mon Nov 15, 2004 7:43 am     Reply with quote
I'am using Opamp and Comparator within circuit inverter
