rickydee
enum compiler bug or poor programmer? |
Posted: Sat Nov 13, 2004 12:16 pm |
I think I found a bug in the compiler. I'm using version 3.184. When I run this code, I get the compiler error"Expecting a , or )". However, if I place in comment the function prototypes (which are optional here), the compiler detects no error. If I keep the prototypes, but change the function enum parameters for int1, I get no error too.
Is this really a bug or am I a crazy?
Here's my code:
#include <18f458.h>
#fuses HS,NOLVP,NOWDT,PUT
#use delay(clock=8000000)
#use rs232(baud=38400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#define BATTERY_FOR_5V_STAT_PIN PIN_A2
#define BATTERY_FOR_5V_HDQ_PIN PIN_A3
#define BATTERY_FOR_12V_STAT_PIN PIN_A1
#define BATTERY_FOR_12V_HDQ_PIN PIN_A4
enum EBatterySource {eBatteryFor5V, eBatteryFor12V};
// function prototypes which to place in comment
void OutputHDQ(EBatterySource eBatterySource, int1 nBitToSend);
int1 InputHDQ(EBatterySource eBatterySource);
if(eBatterySource == eBatteryFor5V)
if(nBitToSend == 1)
output_high(BATTERY_FOR_5V_HDQ_PIN);
output_low(BATTERY_FOR_5V_HDQ_PIN);
} else if(eBatterySource == eBatteryFor12V)
if(nBitToSend == 1)
output_high(BATTERY_FOR_12V_HDQ_PIN);
output_low(BATTERY_FOR_12V_HDQ_PIN);
} else
printf("Error in OutputHDQ(): eBatterySource = %d\r\n", eBatterySource);
return input(BATTERY_FOR_5V_HDQ_PIN);
return input(BATTERY_FOR_12V_HDQ_PIN);
} else
printf("Error in InputHDQ(): eBatterySource = %d\r\n", eBatterySource);
main()
OutputHDQ(eBatteryFor5V, 0);
input(eBatteryFor5V);
Posted: Sat Nov 13, 2004 1:36 pm |
By default, the compiler is not case sensitive.
You can enable it by adding the line shown below, in bold.
However, I would never use identifers which differ only
by case. It's just too error prone.
#include <18f458.h>
#case // This turns on case sensitivity |
