Twitie
Need help in RB0 external interrupt |
Posted: Wed Nov 10, 2004 3:26 am |
#include <16f877a.h>
#fuses HS,NOLVP,NOWDT,PUT
int1 found_it;
#int_ext
void ext_isr()
found_it = true;
found_it = false;
set_tris_b(0x01);
enable_interrupts(global); // set GIE in INTCON register
enable_interrupts(int_ext); // set INTE in INTCON register
ext_int_edge(H_TO_L); // initially RB0 is high (button is not pressed)
// clear INTEDG in OPTION_REG register
if (found_it)
found_it = false;
output_high(PIN_D1);
delay_ms(2000);
delay_ms(300);
output_low(PIN_D1);
delay_ms(300);
I write this for RB0 interrupt but it don't work. I have studied the datasheet and follow the requirement. Is there any important point I miss out? Anyone can help me? THX! |
Juan Pablo Guest
Problem with RB0 interrupt |
Posted: Wed Nov 10, 2004 5:34 am |
Try putting the next lines of code in this order:
ext_int_edge(H_to_L);
enable_interrupts(INT_EXT);
Best Wishes. |
Posted: Wed Nov 10, 2004 5:45 am |
Have you checked the voltage levels on input pin_B0? Are they 5V with switch open and 0V with the switch closed?
Please note that by default the internal pull-up resistors on port-b are disabled, so you either need external pull-up resistors or use PORT_B_PULLUPS(TRUE) for enabling the internal pull-ups. |
Twitie
Posted: Thu Nov 11, 2004 7:58 pm |
My port RB0 is initially high(5V). It turns to low when I press the button. I have set the port_b_pullups but still cannot work...
found_it = false;
set_tris_b(0x01);
port_b_pullups(TRUE);
Mark
Posted: Thu Nov 11, 2004 8:38 pm |
You don't have anything else attached to portb do you? Namely RB0? I tried an experiment with a PICDEM2 Plus board. RB0 has an LED on it along with RB3-RB1. I wanted to use one of the another LEDs but enabling the LEDs with the jumper caused a problem. Otherwise, the code worked fine and I got the int. |
Twitie
Posted: Thu Nov 11, 2004 8:56 pm |
Do you mean that all the portb pins should be 'free'? I connect my RB0 to a button (initially open) and my RD1 to a LED. |
Mark
Posted: Thu Nov 11, 2004 9:58 pm |
Quote: | Do you mean that all the portb pins should be 'free'? |
No, just RB0 |
Twitie
Posted: Thu Nov 11, 2004 10:35 pm |
I connect my RB0 to a normally-open push button. This connection is correct right?
................ __
RB0 --------o o-------- Gnd
............push buttton
and I internally pull port b to high using "port_b_pullups(TRUE);" and clear the INTEDG using "ext_int_edge(H_TO_L);".
Since you have tested my code and it is working.... I think I have to check my circuit. |
