Compiler 3.191 ( Wizard problem )
Begin
PostPosted: Thu Nov 11, 2004 4:57 am     Reply with quote
I have updated my compiler by 3.191 version ( from 3.184 )
IDE 3.143
PCB,PCW,PCH 3.191
Windows XP Professional V.2002 S.P. 2
I can't configure my PIC16C781 for A/D module, because the
window is Blank ! The window has only two combobox to configure
Option button for A/D channel not exist
The PIC16c781 has 8 A/D channel
Can you help me?
Thank
G.
PostPosted: Thu Nov 11, 2004 2:27 pm     Reply with quote
I think they removed support for the A/D converter for the 16c781
in PCM vs. 3.191. You'll either have to upgrade the compiler or
setup the A/D configuration manually, with code.
For your information, here's the ASM code produced by version 3.212.
I haven't checked it, but assuming it's correct, you could use it as a
guide for writing your own A/D functions.
0000                00228 .................... void main()
0000                00229 .................... {
0019 0184       00230 CLRF   04
001A 301F       00231 MOVLW  1F
001B 0583       00232 ANDWF  03,F
001C 1683       00233 BSF    03.5
001D 121F       00234 BCF    1F.4
001E 129F       00235 BCF    1F.5
001F 3000       00236 MOVLW  00
0020 009D       00237 MOVWF  1D
0021 3007       00238 MOVLW  07
0022 1283       00239 BCF    03.5
0023 009F       00240 MOVWF  1F
0000                00241 .................... char c;
0000                00242 ....................
0000                00243 .................... setup_port_a(sAN0);
0024 1683       00244 BSF    03.5
0025 121F       00245 BCF    1F.4
0026 129F       00246 BCF    1F.5
0027 3000       00247 MOVLW  00
0028 3801       00248 IORLW  01
0029 009D       00249 MOVWF  1D
0000                00250 .................... setup_adc(ADC_CLOCK_INTERNAL);
002A 1283       00251 BCF    03.5
002B 171F       00252 BSF    1F.6
002C 179F       00253 BSF    1F.7
002D 141F       00254 BSF    1F.0
0000                00255 .................... set_adc_channel(0);
002E 3000       00256 MOVLW  00
002F 00A1       00257 MOVWF  21
0030 081F       00258 MOVF   1F,W
0031 39C5       00259 ANDLW  C5
0032 0421       00260 IORWF  21,W
0033 009F       00261 MOVWF  1F
0000                00262 ....................
0000                00263 .................... while(1)
0000                00264 ....................   {
0000                00265 ....................    c = read_adc();
0034 151F       00266 BSF    1F.2
0035 191F       00267 BTFSC  1F.2
0036 2835       00268 GOTO   035
0037 081E       00269 MOVF   1E,W
0038 00A3       00270 MOVWF  23
Begin
PostPosted: Fri Nov 12, 2004 7:34 am     Reply with quote
Thanks, but I have downloaded 3.212 version.
On-line there are two version 3.191 and 3.212, why?
Haplo
PostPosted: Fri Nov 12, 2004 3:58 pm     Reply with quote
3.191 is the 'stable' version, while 3.212 is the latest (and beta) version. which may contain bugs.
