I would like to find out where the code resumes after an interrupt.
Say I have a main which is being executed. Then an interrupt occurs.
After the interrupt routine is finished, does the code go back to
the beginning of main, or to where the code was before the interrupt
occured?
Is there any way to get the code to resume where it stopped executing after the interrupt occurs?
Thank you
arrow
Mark
Posted: Wed Nov 10, 2004 1:40 pm
Resumes where it left off.
SherpaDoug
Posted: Wed Nov 10, 2004 2:32 pm
That is the whole idea behind an interrupt. The Main code never knows the interrupt happened. A little time disappears and the effects of the interrupt are simply there. Just like a medical exam by space aliens. _________________ The search for better is endless. Instead simply find very good and get the job done.
treitmey
