treitmey
How do I #locate a 2-D array |
Posted: Wed Nov 10, 2004 5:52 pm |
Compiler 3.212
16F877 @ 16MhZ
i want to #locate the different parts of a 2-d array.
can this be done?
Code: | int8 table[4][25];
#locate table[0]=0x110
#locate table[1]=0x129
#locate table[2]=0x190
#locate table[3]=0x1A9
so that each of the four is able to fit in the ram page.
Thanks in advace for any help.
tjr |
Haplo
Posted: Wed Nov 10, 2004 5:59 pm |
No you can't break an array like that. And too be sure I tried it and the compiler returns an error.
One way to do this is to define 4 separate arrays, and then write wrapper functions (with two parameters) for accessing them. |
treitmey
Posted: Thu Nov 11, 2004 8:44 am |
I understand the 4 arrays. But how are the wrapper functions made. What are they suppose to do? Are they to FAKE out program, to make it look like i'm using a 2-d array?
Code: | int8 table0[24];
int8 table1[24];
int8 table2[24];
int8 table3[24];
// and #locate if need be.
FAKEOUT(param1,param2)
I was thinking that with the 4 arrays, I could have an array of pointers to them. Then I could pass these to the function. Is that where you were going. In effect a 4 ellement array of pointers to 4 arrays.
THANKS FOR THE RESPONSE
tjr |
Posted: Thu Nov 11, 2004 12:40 pm |
Here is one example that I did in the past. It possibly could be
re-written in a more efficient way, but this example will give you
the main idea.
// bigarray.c
// This program shows how to make "wrapper" functions
// to allow access to an array larger than one ram bank.
// INCLUDE FILES
#include "16F877.h"
#device *=16
// COMPILER AND CHIP CONFIGURATION DIRECTIVES
#fuses XT, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
#use Delay(Clock=4000000)
#zero_ram
// DEFINITIONS
#define ARRAY_1_SIZE 80
#define ARRAY_2_SIZE 80
#define TOTAL_ARRAY_SIZE (ARRAY_1_SIZE + ARRAY_2_SIZE)
// GLOBALS
char array_1[ARRAY_1_SIZE];
char array_2[ARRAY_2_SIZE];
// FUNCTION PROTOTYPES
char read_big_array(char index);
void write_big_array(char index, char value);
main()
char i;
char temp;
printf("Start test\n\r");
// To test the functions, we will fill the big array
// with numbers equal to the index.
for(i = 0; i < TOTAL_ARRAY_SIZE; i++)
write_big_array(i, i);
// Now read them back and check the results.
temp = read_big_array(i);
if(temp != i)
printf("Error: Address %02x, Wrote %02x, Read %02x\n\r", i, i, temp);
printf("Test done");
// This function reads a byte from the specified index.
char retval;
if(index < ARRAY_1_SIZE) // Is index within 1st array ?
retval = array_1[index];
else if(index < TOTAL_ARRAY_SIZE) // Is index within 2nd array ?
index -= ARRAY_1_SIZE; // Then adjust index so it's within array 2.
retval = array_2[index];
else // If not in either array, then return zero. (We have to return something).
retval = 0;
return(retval);
// This function writes a byte to the specified index.
if(index >= TOTAL_ARRAY_SIZE) // Don't allow writing outside of the array limits
return;
if(index < ARRAY_1_SIZE) // Is the index within array 1 ?
array_1[index] = value;
else // If not, it must be within array 2.
index -= ARRAY_1_SIZE; // Adjust the index so it's within array 2.
array_2[index] = value;
