Changing PWM frequency
swong
PostPosted: Mon Nov 08, 2004 5:32 pm     Reply with quote
Try to change PWM frequency on the fly.
int pwm_period;
setup_timer_2(T2_DIV_BY_1, 39, 1); //this works
pwm_period = 39;
setup_timer_2(T2_DIV_BY_1, pwm_period, 1); //this doesn't
Am I doing something that can't be done?
Any help would be appreciated.
Using PCH version 3.174
Thanks in advance,
swong
Mark
PostPosted: Mon Nov 08, 2004 6:09 pm     Reply with quote
Edit - nevermind, thought you wanted duty. Kid is calling, gotta go
Mark
PostPosted: Tue Nov 09, 2004 7:39 am     Reply with quote
Didn't test using a variable for the setup_timer_2() function but I'll believe that it can't be done. The pwm_period as you call it is nothing more than the value in the PR2 register. So you could do this
PR2 = pwm_period;
Of course you will need to define the PR2 register according to then chip that you are using.
swong
PostPosted: Tue Nov 09, 2004 1:23 pm     Reply with quote
PR2 = pwm_period;
Try that and is doesn't work. And yes I have defined the PR2 register for the 18F252. And the following code does work:
PR2 = 39;
Looking at the LST file the PR2 does get written in both cases. The only difference is:
    movf pwm_period, W
    and
    movlw 0x27
Mark
PostPosted: Tue Nov 09, 2004 2:21 pm     Reply with quote
Post a small sample program and I'll test it for you.
