write program eeprom 18f252
eaton
PostPosted: Tue Nov 23, 2004 6:26 am     Reply with quote
I am trying to write some dynamic data to program eeprom. The first time the code calls for this after programming, it works as intended. any subsequent calls write garbage into the memory. I'm wondering if the programming clears some control bit that does not get cleared after the first write is performed. the 252 data sheet is pretty clear on the process to write and read from program memory. The CCS data concerning this function is not very in depth.
Any help would be greatly appreciated
PostPosted: Tue Nov 23, 2004 6:57 am     Reply with quote
So, what do you want us to do? You don't give us a lot to work with...
What compiler version are you using? There was a bug in some recent versions.
Post a small program that shows your problem.
eaton
PostPosted: Tue Nov 23, 2004 1:04 pm     Reply with quote
the obvious problems are always the hardest. A block erase is required before write_program_eeprom() will successfully write into program memory.
