PIC to PIC SPI (again!)
Kieran
PostPosted: Mon Nov 08, 2004 1:49 pm     Reply with quote
The following code follows suggestion in previous posts.
PCWH version 3.212 PIC18F452 at both ends.
Master
snippet - data clock and SS drive all present on scope.
Slave - stripped down to bare essentials
For each SS low period from the master only the first byte of the 6 sent generates an SSP interrupt at the slave. Using SS select and interrupt driven reciever.
MASTER SNIPPET
write_to_slave(byte dat)
   spi_write(dat);
   delay_ms(2);
// Output a few bytes
send_spi()
   setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_64 |
        SS_DISABLED);
   delay_ms(1);
   SPISSOUT = 0; // Select slave
   delay_ms(1);
   write_to_slave(0x30);
   write_to_slave(0x31);
   write_to_slave(0x32);
   write_to_slave(0x33);
   write_to_slave(0x34);
   write_to_slave(0x35);
   write_to_slave('\r');
   SPISSOUT = 1; // Deselect slave
SLAVE CODE
#include <18F452.h>
#device ADC=10
#fuses  H4,NOPROTECT,PUT,WDT,WDT64,NOLVP,BROWNOUT,BORV45
#priority SSP
#byte PORTA = 0xF80
#byte PORTB = 0xF81
#byte PORTC = 0xF82
#byte PORTD = 0xF83
#byte PORTE = 0xF84
#byte SSPBUF = 0xFC9
#use delay(clock=40000000, RESTART_WDT)
#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,errors)
#zero_ram
#define IDDRA         0b00100000   // SS inpu
#define IDDRB         0b00000010
#define IDDRC         0b10011000
#define IDDRD         0b11111111
#define IDDRE         0b00000000
#define IPORTA        0b00100000   // SS high
#define IPORTB        0b00000000
#define IPORTC        0b10000010
#define IPORTD        0b00000000
#define IPORTE         0b00000000
spi_init()
   setup_spi(SPI_SLAVE | SPI_H_TO_L);
   enable_interrupts(INT_SSP);
// Receive SPI
#INT_SSP
spi_isr()
char spi_dat;
   output_low(PIN_C1);
   spi_dat = spi_read();  // Get the data
   delay_cycles(40); // Need a short delay to see pulse on scope
   output_high(PIN_C1); // Scope to see ints
char k;
   restart_WDT();
   PORTA = IPORTA;
   PORTB = IPORTB;
   PORTC = IPORTC;
   PORTD = IPORTD;
   PORTE = IPORTE;
   set_tris_a(IDDRA);
   set_tris_b(IDDRB);
   set_tris_c(IDDRC);
   set_tris_d(IDDRD);
   set_tris_e(IDDRE);
   printf("Start\r");
   spi_init();
   while (1)
      restart_WDT();
Any Ideas?
This should be easy, SPI works brilliantly with loads of external devices.
Why is it so hard with 2 PICs?
PostPosted: Mon Nov 08, 2004 2:10 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=328&highlight=intssp+spi+i2c
Kieran
SPI receive problems
PostPosted: Mon Nov 08, 2004 3:33 pm     Reply with quote
Thanks PCM programmer
I missed that post.
I have just tried replacing
with
spi_dat = SSPBUF;
No change, I thought these were functionally the same.
Doesn't spi_read wait only if you pass data in e.g. spi_read(0x55).
Kieran
