dan king
| yes, another bootloader question re: ccs bootloader |
Posted: Tue Oct 26, 2004 9:34 am |
I have decided to explore the ccs provided bootloader and am using compiler ver 3.130. The code sample compiles ok but when I use the ICD to program a 16f877, MPLAB warns that the code is addressing beyond address 0x2000 ?? I programmed the part anyhow and the bootloader begins to operate but when the L is entered to invoke the loader and I send the hex file via the send text file nothing happens. I am using hyperterm set for Xon/Xoff at 9600 baud. Any suggestions would be welcome.
Thanks Dan |
Posted: Tue Oct 26, 2004 12:13 pm |
The Config Word for a 16F877 is at address 0x2007.
Hex files use byte addresses, so this will be seen as 0x400E.
Example:
:02400E00713F00
Is it possible that your programmer is set to prevent the Config Bits
from being programmed ?
If you think code has been put at an address above 0x1FFF, then
check the HEX file.
With respect to the apparent lock-up, the CCS example doesn't
have the 'Errors' parameter in the #use rs232() statement. You
could add it. You'd still get the error, but at least it wouldn't lock
up the program.
One simple way to track the progress of the program is to put in
little putc() statements, such as putc('A'), putc('B'), putc('C'), etc.
and when it locks up, you can see right where it happened.
I don't know how much space is left in that loader to allow for adding
these debug statements. You should check the .LST file to see. |
dan king
Posted: Tue Oct 26, 2004 1:28 pm |
I have included the list file, it appears that the bootloader code is being overwritten? Shouldn't the majority of the code be located at the high end of program memory? I'm not used to reviewing LST files so I'm interpreting that the address is the left most column and it appears that a lot of the boot code is low in memory.
You mentioned that the hex file can be viewed to verify the addressing, can't the lst file be used as well? I am not familiar with the format for hex files, so I don't see the pattern in your Example :(
I believe the config bits are being programmed with the ICD programmer because I have been using a assembly version bootloader that someone gave me and that programs fine. I wanted to start using a C loader that I could understand a little better. Not having much success with that
I don't think I'm getting lockups, I think the boot code is being overwritten because a reset on the board after a transfer attempt does absolutely nothing. I have to reprogram with the ICD to get the code to respond again.
I typically use your suggested method of tracing with messages by sending characters, just didn't get that far yet.
Thanks for your help so far.
| Code: | CCS PCM C Compiler, Version 3.130, 17162
Filename: D:\MICROC~1\BOOT\EX_LOAD.LST
ROM used: 488 (6%)
Largest free fragment is 2048
RAM used: 71 (41%) at main() level
136 (78%) worst case
Stack: 3 locations
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 05F
0003: NOP
.................... //// EX_LOAD.C ////
.................... //// This program uses the loader driver to show how you can ////
.................... //// read and write to an internal program memory. ////
.................... //// The LOADER.C will take an Intel 8-bit Hex file over RS232 ////
.................... //// and modify the flash program memory with the new code. ////
.................... //// After each good line, the loader sends an ACK character. The ////
.................... //// driver uses XON/XOFF flow control. Also, any buffer on the PC ////
.................... //// UART must be turned off, or to its lowest setting, otherwise it////
.................... //// will miss data. ////
.................... //// A program such as Hyper-Term may be used to simply transmit the////
.................... //// .HEX file output from the compiler. ////
.................... //// This example will work with the PCM and PCH compilers. The ////
.................... //// following conditional compilation lines are used to include a ////
.................... //// valid device for each compiler. Change the device, clock and ////
.................... //// RS232 pins for your hardware if needed. ////
.................... //// (C) Copyright 1996,2001 Custom Computer Services ////
.................... //// This source code may only be used by licensed users of the CCS ////
.................... //// C compiler. This source code may only be distributed to other ////
.................... //// licensed users of the CCS C compiler. No other use, ////
.................... //// reproduction or distribution is permitted without written ////
.................... //// permission. Derivative programs created using this software ////
.................... //// in object code form are not restricted in any way. ////
.................... #if defined(__PCM__)
.................... #include <16f877.h>
.................... //////// Standard Header file for the PIC16F877 device ////////////////
.................... #device PIC16F877
.................... #list
.................... #fuses HS,NOWDT,NOPROTECT
.................... #use delay(clock=4000000)
0048: MOVLW 62
0049: MOVWF 04
004A: MOVF 00,W
004B: BTFSC 03.2
004C: GOTO 05C
004D: MOVLW 01
004E: MOVWF 78
004F: CLRF 77
0050: DECFSZ 77,F
0051: GOTO 050
0052: DECFSZ 78,F
0053: GOTO 04F
0054: MOVLW 4A
0055: MOVWF 77
0056: DECFSZ 77,F
0057: GOTO 056
0058: NOP
0059: NOP
005A: DECFSZ 00,F
005B: GOTO 04D
005C: BCF 0A.3
005D: BCF 0A.4
005E: GOTO 071 (RETURN)
.................... #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
.................... #elif defined(__PCH__)
.................... #include <18f452.h>
.................... #fuses HS,NOPROTECT
.................... #use delay(clock=20000000)
.................... #endif
.................... #include <loader.c>
.................... //// loader.c ////
.................... //// This driver will take an Intel 8-bit Hex file over RS232 channels ////
.................... //// and modify the flash program memory with the new code. A proxy ////
.................... //// function is required to sit between the real loading function ////
.................... //// and the main code because the #org preprocessor command could ////
.................... //// possibly change the order of functions within a defined block. ////
.................... //// After each good line, the loader sends an ACKLOD character. The ////
.................... //// UART must be turned off, or to its lowest setting, otherwise it ////
.................... //// (C) Copyright 1996,2003 Custom Computer Services ////
.................... //// This source code may only be used by licensed users of the CCS C ////
.................... //// compiler. This source code may only be distributed to other ////
.................... //// licensed users of the CCS C compiler. No other use, reproduction ////
.................... //// or distribution is permitted without written permission. ////
.................... //// Derivative programs created using this software in object code ////
.................... //// form are not restricted in any way. ////
.................... #define LOADER_END getenv("PROGRAM_MEMORY")-1
.................... #define LOADER_SIZE 0x15F
.................... #define LOADER_SIZE 0x3FF
.................... #define LOADER_ADDR LOADER_END-LOADER_SIZE
.................... #define BUFFER_LEN_LOD 64
.................... int buffidx;
.................... char buffer[BUFFER_LEN_LOD];
.................... #define ACKLOD 0x06
.................... #define XON 0x11
.................... #define XOFF 0x13
.................... #SEPARATE
.................... unsigned int atoi_b16(char *s);
.................... #ORG LOADER_ADDR+10, LOADER_END auto=0 default
.................... void real_load_program (void)
.................... int1 do_ACKLOD, done=FALSE;
.................... int8 checksum, line_type;
.................... int16 l_addr,h_addr=0;
.................... int32 addr,next_addr;
.................... int8 dataidx, i, count;
1EE5: BCF 61.1
1EE6: CLRF 66
1EE7: CLRF 67
.................... int8 data[32];
.................... while (!done) // Loop until the entire program is downloaded
1EE8: BTFSC 61.1
1EE9: GOTO 7E8
.................... buffidx = 0; // Read into the buffer until 0x0D ('\r') is received or the buffer is full
1EEA: CLRF 20
.................... do {
.................... buffer[buffidx++] = getc();
1EEB: MOVF 20,W
1EEC: INCF 20,F
1EED: ADDLW 21
1EEE: MOVWF 04
1EEF: BTFSS 0C.5
1EF0: GOTO 6EF
1EF1: MOVF 1A,W
1EF2: MOVWF 00
.................... } while ( (buffer[buffidx-1] != 0x0D) && (buffidx <= BUFFER_LEN_LOD) );
1EF3: MOVLW 01
1EF4: SUBWF 20,W
1EF5: ADDLW 21
1EF6: MOVWF 04
1EF7: MOVF 00,W
1EF8: SUBLW 0D
1EF9: BTFSC 03.2
1EFA: GOTO 6FF
1EFB: MOVF 20,W
1EFC: SUBLW 40
1EFD: BTFSC 03.0
1EFE: GOTO 6EB
.................... putchar (XOFF); // Suspend sender
1EFF: MOVLW 13
1F00: BTFSS 0C.4
1F01: GOTO 700
1F02: MOVWF 19
.................... do_ACKLOD = TRUE;
1F03: BSF 61.0
.................... // Only process data blocks that start with ':'
.................... if (buffer[0] == ':') {
1F04: MOVF 21,W
1F05: SUBLW 3A
1F06: BTFSS 03.2
1F07: GOTO 7DD
.................... count = atoi_b16 (&buffer[1]); // Get the number of bytes from the buffer
1F08: MOVLW 22
1F09: BSF 03.5
1F0A: MOVWF 43
1F0B: BCF 03.5
1F0C: CALL 6AA
1F0D: MOVF 78,W
1F0E: MOVWF 72
.................... // Get the lower 16 bits of address
.................... l_addr = make16(atoi_b16(&buffer[3]),atoi_b16(&buffer[5]));
1F0F: MOVLW 24
1F10: BSF 03.5
1F11: MOVWF 43
1F12: BCF 03.5
1F13: CALL 6AA
1F14: MOVF 78,W
1F15: MOVWF 73
1F16: MOVLW 26
1F17: BSF 03.5
1F18: MOVWF 43
1F19: BCF 03.5
1F1A: CALL 6AA
1F1B: MOVF 78,W
1F1C: MOVWF 74
1F1D: MOVF 73,W
1F1E: MOVWF 65
1F1F: MOVF 74,W
1F20: MOVWF 64
.................... line_type = atoi_b16 (&buffer[7]);
1F21: MOVLW 28
1F22: BSF 03.5
1F23: MOVWF 43
1F24: BCF 03.5
1F25: CALL 6AA
1F26: MOVF 78,W
1F27: MOVWF 63
.................... addr = make32(h_addr,l_addr);
1F28: MOVF 66,W
1F29: MOVWF 6A
1F2A: MOVF 67,W
1F2B: MOVWF 6B
1F2C: MOVF 64,W
1F2D: MOVWF 68
1F2E: MOVF 65,W
1F2F: MOVWF 69
.................... #if defined(__PCM__) // PIC16 uses word addresses
.................... addr /= 2;
1F30: BCF 03.0
1F31: RRF 6B,F
1F32: RRF 6A,F
1F33: RRF 69,F
1F34: RRF 68,F
.................... // If the line type is 1, then data is done being sent
.................... if (line_type == 1) {
1F35: DECFSZ 63,W
1F36: GOTO 739
.................... done = TRUE;
1F37: BSF 61.1
.................... } else if (addr < LOADER_ADDR) {
1F38: GOTO 7DD
1F39: MOVF 6B,F
1F3A: BTFSS 03.2
1F3B: GOTO 7DD
1F3C: MOVF 6A,F
1F3D: BTFSS 03.2
1F3E: GOTO 7DD
1F3F: MOVF 69,W
1F40: SUBLW 1E
1F41: BTFSS 03.0
1F42: GOTO 7DD
1F43: BTFSS 03.2
1F44: GOTO 749
1F45: MOVF 68,W
1F46: SUBLW 9F
1F47: BTFSS 03.0
1F48: GOTO 7DD
.................... checksum = 0; // Sum the bytes to find the check sum value
1F49: CLRF 62
.................... for (i=1; i<(buffidx-3); i+=2)
1F4A: MOVLW 01
1F4B: MOVWF 71
1F4C: MOVLW 03
1F4D: SUBWF 20,W
1F4E: SUBWF 71,W
1F4F: BTFSC 03.0
1F50: GOTO 75D
.................... checksum += atoi_b16 (&buffer[i]);
1F51: MOVLW 21
1F52: ADDWF 71,W
1F53: MOVWF 73
1F54: BSF 03.5
1F55: MOVWF 43
1F56: BCF 03.5
1F57: CALL 6AA
1F58: MOVF 78,W
1F59: ADDWF 62,F
1F5A: MOVLW 02
1F5B: ADDWF 71,F
1F5C: GOTO 74C
.................... checksum = 0xFF - checksum + 1;
1F5D: MOVF 62,W
1F5E: SUBLW FF
1F5F: ADDLW 01
1F60: MOVWF 62
.................... if (checksum != atoi_b16 (&buffer[buffidx-3]))
1F61: MOVLW 03
1F62: SUBWF 20,W
1F63: ADDLW 21
1F64: MOVWF 74
1F65: BSF 03.5
1F66: MOVWF 43
1F67: BCF 03.5
1F68: CALL 6AA
1F69: MOVF 78,W
1F6A: SUBWF 62,W
1F6B: BTFSC 03.2
1F6C: GOTO 76F
.................... do_ACKLOD = FALSE;
1F6D: BCF 61.0
.................... else {
1F6E: GOTO 7DD
.................... if (line_type == 0) {
1F6F: MOVF 63,F
1F70: BTFSS 03.2
1F71: GOTO 7C7
.................... // Loops through all of the data and stores it in data
.................... // The last 2 bytes are the check sum, hence buffidx-3
.................... for (i = 9,dataidx=0; i < buffidx-3; i += 2)
1F72: MOVLW 09
1F73: MOVWF 71
1F74: CLRF 70
1F75: MOVLW 03
1F76: SUBWF 20,W
1F77: SUBWF 71,W
1F78: BTFSC 03.0
1F79: GOTO 78C
.................... data[dataidx++]=atoi_b16(&buffer[i]);
1F7A: MOVF 70,W
1F7B: INCF 70,F
1F7C: ADDLW A0
1F7D: MOVWF 74
1F7E: MOVLW 21
1F7F: ADDWF 71,W
1F80: MOVWF 75
1F81: BSF 03.5
1F82: MOVWF 43
1F83: BCF 03.5
1F84: CALL 6AA
1F85: MOVF 74,W
1F86: MOVWF 04
1F87: MOVF 78,W
1F88: MOVWF 00
.................... #if getenv("FLASH_ERASE_SIZE")>2
1F89: MOVLW 02
1F8A: ADDWF 71,F
1F8B: GOTO 775
.................... if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")-1)!=0))
.................... #else
.................... if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")/2-1)!=0))
.................... erase_program_eeprom(addr);
.................... write_program_memory(addr, data, count);
1F8C: MOVF 68,W
1F8D: BSF 03.6
1F8E: MOVWF 0D
1F8F: BCF 03.6
1F90: MOVF 69,W
1F91: BSF 03.6
1F92: MOVWF 0F
1F93: MOVLW A0
1F94: MOVWF 04
1F95: BCF 03.6
1F96: MOVF 72,W
1F97: MOVWF 79
1F98: RRF 79,F
1F99: MOVF 00,W
1F9A: BSF 03.6
1F9B: MOVWF 0C
1F9C: INCF 04,F
1F9D: MOVF 00,W
1F9E: MOVWF 0E
1F9F: INCF 04,F
1FA0: BSF 03.5
1FA1: BSF 0C.7
1FA2: BSF 0C.2
1FA3: BCF 03.5
1FA4: BCF 03.6
1FA5: MOVF 0B,W
1FA6: MOVWF 78
1FA7: BCF 0B.7
1FA8: BSF 03.5
1FA9: BSF 03.6
1FAA: MOVLW 55
1FAB: MOVWF 0D
1FAC: MOVLW AA
1FAD: MOVWF 0D
1FAE: BSF 0C.1
1FAF: NOP
1FB0: NOP
1FB1: BCF 03.5
1FB2: BCF 03.6
1FB3: BSF 03.5
1FB4: BSF 03.6
1FB5: BTFSS 0C.1
1FB6: GOTO 7BA
1FB7: BCF 03.5
1FB8: BCF 03.6
1FB9: GOTO 7B3
1FBA: BCF 0C.2
1FBB: BCF 03.5
1FBC: BCF 03.6
1FBD: MOVF 78,W
1FBE: IORWF 0B,F
1FBF: BSF 03.6
1FC0: INCF 0D,F
1FC1: BTFSC 03.2
1FC2: INCF 0F,F
1FC3: BCF 03.6
1FC4: DECFSZ 79,F
1FC5: GOTO 799
.................... else if (line_type == 4)
1FC6: GOTO 7DD
1FC7: MOVF 63,W
1FC8: SUBLW 04
1FC9: BTFSS 03.2
1FCA: GOTO 7DD
.................... h_addr = make16(atoi_b16(&buffer[9]), atoi_b16(&buffer[11]));
1FCB: MOVLW 2A
1FCC: BSF 03.5
1FCD: MOVWF 43
1FCE: BCF 03.5
1FCF: CALL 6AA
1FD0: MOVF 78,W
1FD1: MOVWF 73
1FD2: MOVLW 2C
1FD3: BSF 03.5
1FD4: MOVWF 43
1FD5: BCF 03.5
1FD6: CALL 6AA
1FD7: MOVF 78,W
1FD8: MOVWF 74
1FD9: MOVF 73,W
1FDA: MOVWF 67
1FDB: MOVF 74,W
1FDC: MOVWF 66
.................... if (do_ACKLOD)
1FDD: BTFSS 61.0
1FDE: GOTO 7E3
.................... putchar (ACKLOD);
1FDF: MOVLW 06
1FE0: BTFSS 0C.4
1FE1: GOTO 7E0
1FE2: MOVWF 19
.................... putchar(XON);
1FE3: MOVLW 11
1FE4: BTFSS 0C.4
1FE5: GOTO 7E4
1FE6: MOVWF 19
1FE7: GOTO 6E8
1FE8: MOVLW 06
1FE9: BTFSS 0C.4
1FEA: GOTO 7E9
1FEB: MOVWF 19
1FEC: MOVLW 11
1FED: BTFSS 0C.4
1FEE: GOTO 7ED
1FEF: MOVWF 19
.................... reset_cpu();
1FF0: CLRF 0A
1FF1: GOTO 000
1FF2: RETLW 00
.................... unsigned int atoi_b16(char *s) { // Convert two hex characters to a int8
.................... unsigned int result = 0;
1EAA: BSF 03.5
1EAB: CLRF 44
.................... int i;
.................... for (i=0; i<2; i++,s++) {
1EAC: CLRF 45
1EAD: BCF 03.5
1EAE: BSF 03.5
1EAF: MOVF 45,W
1EB0: SUBLW 01
1EB1: BTFSC 03.0
1EB2: GOTO 6B5
1EB3: BCF 03.5
1EB4: GOTO 6E0
1EB5: BCF 03.5
.................... if (*s >= 'A')
1EB6: BSF 03.5
1EB7: MOVF 43,W
1EB8: MOVWF 04
1EB9: MOVF 00,W
1EBA: SUBLW 40
1EBB: BTFSS 03.0
1EBC: GOTO 6BF
1EBD: BCF 03.5
1EBE: GOTO 6CE
1EBF: BCF 03.5
.................... result = 16*result + (*s) - 'A' + 10;
1EC0: BSF 03.5
1EC1: SWAPF 44,W
1EC2: MOVWF 46
1EC3: MOVLW F0
1EC4: ANDWF 46,F
1EC5: MOVF 43,W
1EC6: MOVWF 04
1EC7: MOVF 00,W
1EC8: ADDWF 46,W
1EC9: ADDLW BF
1ECA: ADDLW 0A
1ECB: MOVWF 44
1ECC: BCF 03.5
1ECD: GOTO 6DA
.................... result = 16*result + (*s) - '0';
1ECE: BSF 03.5
1ECF: SWAPF 44,W
1ED0: MOVWF 46
1ED1: MOVLW F0
1ED2: ANDWF 46,F
1ED3: MOVF 43,W
1ED4: MOVWF 04
1ED5: MOVF 00,W
1ED6: ADDWF 46,W
1ED7: ADDLW D0
1ED8: MOVWF 44
1ED9: BCF 03.5
1EDA: BSF 03.5
1EDB: MOVF 45,W
1EDC: INCF 45,F
1EDD: INCF 43,F
1EDE: BCF 03.5
1EDF: GOTO 6AE
.................... return(result);
1EE0: BSF 03.5
1EE1: MOVF 44,W
1EE2: BCF 03.5
1EE3: MOVWF 78
1EE4: RETLW 00
.................... #ORG default
.................... #ORG LOADER_ADDR, LOADER_ADDR+9
.................... void load_program(void)
.................... real_load_program();
1EA0: CALL 6E5
1EA1: RETLW 00
005F: CLRF 04
0060: MOVLW 1F
0061: ANDWF 03,F
0062: MOVLW 07
0063: BSF 03.5
0064: MOVWF 1F
0065: MOVLW 19
0066: MOVWF 19
0067: MOVLW 26
0068: MOVWF 18
0069: MOVLW 90
006A: BCF 03.5
006B: MOVWF 18
.................... //clears out the rs232 buffer
.................... delay_ms (1000);
006C: MOVLW 04
006D: MOVWF 61
006E: MOVLW FA
006F: MOVWF 62
0070: GOTO 048
0071: DECFSZ 61,F
0072: GOTO 06E
.................... while (kbhit())
0073: BTFSS 0C.5
0074: GOTO 079
.................... getc();
0075: BTFSS 0C.5
0076: GOTO 075
0077: MOVF 1A,W
0078: GOTO 073
.................... printf("\r\nSoftware Version A!\r\n");
0004: BCF 0A.0
0005: BCF 0A.1
0006: BCF 0A.2
0007: ADDWF 02,F
0008: RETLW 0D
0009: RETLW 0A
000A: RETLW 53
000B: RETLW 6F
000C: RETLW 66
000D: RETLW 74
000E: RETLW 77
000F: RETLW 61
0010: RETLW 72
0011: RETLW 65
0012: RETLW 20
0013: RETLW 56
0014: RETLW 65
0015: RETLW 72
0016: RETLW 73
0017: RETLW 69
0018: RETLW 6F
0019: RETLW 6E
001A: RETLW 20
001B: RETLW 41
001C: RETLW 21
001D: RETLW 0D
001E: RETLW 0A
001F: RETLW 00
0079: CLRF 61
007A: MOVF 61,W
007B: CALL 004
007C: INCF 61,F
007D: MOVWF 77
007E: BTFSS 0C.4
007F: GOTO 07E
0080: MOVWF 19
0081: MOVLW 17
0082: SUBWF 61,W
0083: BTFSS 03.2
0084: GOTO 07A
.................... printf("Press L to download new software.\r\n");
0020: BCF 0A.0
0021: BCF 0A.1
0022: BCF 0A.2
0023: ADDWF 02,F
0024: RETLW 50
0025: RETLW 72
0026: RETLW 65
0027: RETLW 73
0028: RETLW 73
0029: RETLW 20
002A: RETLW 4C
002B: RETLW 20
002C: RETLW 74
002D: RETLW 6F
002E: RETLW 20
002F: RETLW 64
0030: RETLW 6F
0031: RETLW 77
0032: RETLW 6E
0033: RETLW 6C
0034: RETLW 6F
0035: RETLW 61
0036: RETLW 64
0037: RETLW 20
0038: RETLW 6E
0039: RETLW 65
003A: RETLW 77
003B: RETLW 20
003C: RETLW 73
003D: RETLW 6F
003E: RETLW 66
003F: RETLW 74
0040: RETLW 77
0041: RETLW 61
0042: RETLW 72
0043: RETLW 65
0044: RETLW 2E
0045: RETLW 0D
0046: RETLW 0A
0047: RETLW 00
0085: CLRF 61
0086: MOVF 61,W
0087: CALL 020
0088: INCF 61,F
0089: MOVWF 77
008A: BTFSS 0C.4
008B: GOTO 08A
008C: MOVWF 19
008D: MOVLW 23
008E: SUBWF 61,W
008F: BTFSS 03.2
0090: GOTO 086
.................... } while (getc()!='L');
0091: BTFSS 0C.5
0092: GOTO 091
0093: MOVF 1A,W
0094: SUBLW 4C
0095: BTFSS 03.2
0096: GOTO 079
.................... load_program ();
0097: BSF 0A.4
0098: BSF 0A.3
0099: CALL 6A0
009A: BCF 0A.4
009B: BCF 0A.3
009C: SLEEP
dan king
Posted: Tue Oct 26, 2004 2:11 pm |
| I found a good app note from microchip (AN732) detailing the hex format. Thanks for the direction, I understand your previous example now and can verify that I don't have code above the max program limit. |
Posted: Tue Oct 26, 2004 2:29 pm |
Before we go any farther, can you do these two things ?
1. Put NOLVP at the end of the #fuses statement.
2. Put ERRORS at the end of the #use rs232() statement.
The changes are shown in bold, below.
#include <16f877.h>
#fuses HS,NOWDT,NOPROTECT, NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS) |
dan king
Posted: Tue Oct 26, 2004 2:44 pm |
Ok, I added the lines you requested but I still get the same response. When I typed my initial post I stated that when I pressed the 'L' nothing happened when I attempted to send the hex file. At that time I had the ending program address for the ICD set to 1EFF, not sure why so I changed it to 1FFF. Since then I get one black spade returned when I attempt to send the hex code. After that, nothing as in I have to reload the bootloader with the ICD because I believe the bootloader was overwritten. This is still the same results after the modifications you requested I make.
Do I need to add a #ORG to the code to be downloaded with the bootloader to prevent the new code from overwriting the bootloader? |
Jeff King
Joined: 20 Oct 2003 Posts: 43 Location: Hillsdale, Michigan USA
Posted: Tue Oct 26, 2004 3:53 pm |
Dan:
Try SIOW.EXE which is available via the "TOOLS" window of the CCS compilier for your uploaded. Under the file menu pulldown, there should be a selection for "Download Software". In developing a client app for the bootloader, I used SIOW as my reference, and it always seemed to work if things where OK with the bootloader.
Also see my recent posting on the bootloader example. Not heard back from CCS but I wouldn't assume things are kosher in the bootloader.
Looking at your code you have:
| Code: | .................... // If the line type is 1, then data is done being sent
1F35: DECFSZ 63,W
1F36: GOTO 739
1F37: BSF 61.1
.................... } else if (addr < LOADER_ADDR) { |
Where as the listing for loader.c was:
done = TRUE;
} else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x2000){
} else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x300000){
and what I think you should have is:
| Code: | | } else if ((addr > LOADER_END) && addr < 0x2000){ |
This will keep the bootloader from overwriting itself, the reset vectors and the config bits.
(and the difference between this and the example bootloader was the basis for my question yesterday).
Let me know how it goes as I have similar concerns.
-Jeff |
dan king
Posted: Thu Nov 04, 2004 9:52 am |
Jeff,
I guess my rev of loader.c is older than yours because the code snippet you included in your previous post is not quite the same in mine.
Either way, I don't think your suggested change will work because Loader_end is the max address in program memory and we just want to check that the new code won't over write the boot code, so checking to verify that addr > loader_end isn't valid. The sample code I have checks for the code address to be < LOADER_ADDR which is valid because that is the start of the bootloader code and as long as we're less than that we should be OK.
One of the several problems I found with the CCS example is that too much code is resident in low memory and gets overwritten with user code which then renders the bootloader useless. The LST file uncovers this problem.
FWIW: I gave up on the CCS bootloader because it needed too many additions to get it to a point of being really useful. A better start is to check out the bootloader code from theByteFactory.com - codeloader_m.c That application works well and covers a lot of the bases for error checking and relocating the reset vector.
Thanks for your input.
Dan |
