MEASURE THE PERIOD OF A SIGNAL
Juan Pablo
PostPosted: Wed Oct 27, 2004 6:25 am     Reply with quote
I am working with a PIC16F877 and a oscilator of 20 MHz.
I need to measure the period of a square wave every 0.5 seconds, so I try to use the RTCC (76 interruptions per second, which I have to use in the programme) and enable the CCP1 interruption every 0.5 seconds, disabling it when the period is obtained:
set_rtcc(0);
setup_counters(RTCC_INTERNAL, RTCC_DIV_256);
enable_interrupts(INT_RTCC);
setup_ccp1(CCP_CAPTURE_RE);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_4);
#int_ccp1 void velocidad() {
long peraux;
disable_interrupts(GLOBAL);
if(!segundo){
//first rising edge
subida1 = CCP_1;
segundo=1;
else{
//second rising edge
subida2 = CCP_1;
peraux = subida2 - subida1;
segundo=0;
//Global int variables
auxi=peraux;
valor=peraux>>8;
disable_interrupts(INT_CCP1);
The period is obtained correctly but the PIC resets itself in 5 or 6 minutes time.
I didnīt use Watchdog, the stack used 4 of its 8 positions, RAM is used at 72 % (worst case) and ROM at 23 %.
Does anybody know why it happens? I can say that if I donīt enable CCP1 the PIC works properly.
Any better idea to implement this application?
Thanks in advance.
PostPosted: Wed Oct 27, 2004 6:48 am     Reply with quote
I know something that happened: your CAPS LOCK was inadvertently activated during the typing of the topic title... Wink
Mark
PostPosted: Wed Oct 27, 2004 6:57 am     Reply with quote
Don't monkey around with the interrupt enable inside of the int. Ints are automatically enabled/disabled. You are enabling the int during and int. If another int occurs, you are going to trash the temp storage.
Juan Pablo
Measuring the frequency of a signal
PostPosted: Thu Oct 28, 2004 5:27 am     Reply with quote
I have placed the next code in main function:
if(activar){
enable_interrupts(INT_CCP1);
activar=0;
else{
if(convertir){
convertir=0;
And it seems that the problem has disappeared.
Thanks for your help!!!!
