#serialize
eric
#serialize
PostPosted: Sat Oct 23, 2004 5:05 pm     Reply with quote
Does anyone have an idea how this serialization works?
I've no idea how to access the serial number. Don't see it reading the
ID locations
From Readme.txt section on serialization
#serialize(id=xxx,next="xxx")
Use only one of the next three options:
file="x" The file x is used to read the serial number from, and this
file is updated by the ICD programmer. It is asumed this is
a one line file with the serial number. The programmer will
increment the serial number.
listfile="x" The file x is used to read the serial number from, and this
a file one serial number per line. The programmer will read the
first line then delete that line from the file.
next="x" The serial number X is used for the first load, then the hex file
is updated to increment x by one.
prompt="text" This option is optional. If specified the user will be prompted
for a serial number on each load. If used with one of the above
three options then the default value the user may use is picked
according to the above rules.
log="xxx" A file may optionaly be specified to keep a log of the date, time,
hex file name and serial number each time the part is programmed.
If no id=xxx is specified then this may be used as a simple log
of all loads of the hex file.
Mark
PostPosted: Sat Oct 23, 2004 10:08 pm     Reply with quote
You can store the serial number either in dataeeprom or as a C CONST. Here are some examples:
//Prompt user for serial number to be placed
//at address of serialNumA
//Default serial number = 200int8 const serialNumA=100;
#serialize(id=serialNumA,next="200",prompt="Enter the serial number")
//Adds serial number log in seriallog.txt
#serialize(id=serialNumA,next="200",prompt="Enter the serial number", log="seriallog.txt")
//Retrieves serial number from serials.txt
#serialize(id=serialNumA,listfile="serials.txt")
//Place serial number at EEPROM address 0, reserving 1 byte
#serialize(dataee=0,binary=1,next="45",prompt="Put in Serial number")
//Place string serial number at EEPROM address 0, reserving 2 bytes
#serialize(dataee=0, string=2,next="AB",prompt="Put in Serial number")
object01
PostPosted: Wed Oct 27, 2004 9:39 am     Reply with quote
I tried that example in the following code using an int32 rather than an int8:
unsigned int32 getUnitID() {
   unsigned int32 const serialNumA = 200;
   return serialNumA;
And every time I try to program the device, I'm prompted correctly. But I can't enter anything other than 0 without getting the error, "The ID code is too big for the memory location."
Jeff S.
