eric
#serialize |
Posted: Sat Oct 23, 2004 5:05 pm |
Does anyone have an idea how this serialization works?
I've no idea how to access the serial number. Don't see it reading the
ID locations
From Readme.txt section on serialization
#serialize(id=xxx,next="xxx")
Use only one of the next three options:
file="x" The file x is used to read the serial number from, and this
file is updated by the ICD programmer. It is asumed this is
a one line file with the serial number. The programmer will
increment the serial number.
listfile="x" The file x is used to read the serial number from, and this
a file one serial number per line. The programmer will read the
first line then delete that line from the file.
next="x" The serial number X is used for the first load, then the hex file
is updated to increment x by one.
prompt="text" This option is optional. If specified the user will be prompted
for a serial number on each load. If used with one of the above
three options then the default value the user may use is picked
according to the above rules.
log="xxx" A file may optionaly be specified to keep a log of the date, time,
hex file name and serial number each time the part is programmed.
If no id=xxx is specified then this may be used as a simple log
of all loads of the hex file. |
Mark
Posted: Sat Oct 23, 2004 10:08 pm |
You can store the serial number either in dataeeprom or as a C CONST. Here are some examples:
Code: | //Prompt user for serial number to be placed
//at address of serialNumA
//Default serial number = 200int8 const serialNumA=100;
#serialize(id=serialNumA,next="200",prompt="Enter the serial number")
//Adds serial number log in seriallog.txt
#serialize(id=serialNumA,next="200",prompt="Enter the serial number", log="seriallog.txt")
//Retrieves serial number from serials.txt
#serialize(id=serialNumA,listfile="serials.txt")
//Place serial number at EEPROM address 0, reserving 1 byte
#serialize(dataee=0,binary=1,next="45",prompt="Put in Serial number")
//Place string serial number at EEPROM address 0, reserving 2 bytes
#serialize(dataee=0, string=2,next="AB",prompt="Put in Serial number")
object01
Joined: 13 May 2004 Posts: 90 Location: Nashville, TN
Posted: Wed Oct 27, 2004 9:39 am |
Mark wrote: | You can store the serial number either in dataeeprom or as a C CONST. Here are some examples:
#serialize(id=serialNumA,next="200",prompt="Enter the serial number") |
I tried that example in the following code using an int32 rather than an int8:
Code: | unsigned int32 getUnitID() {
unsigned int32 const serialNumA = 200;
return serialNumA;
And every time I try to program the device, I'm prompted correctly. But I can't enter anything other than 0 without getting the error, "The ID code is too big for the memory location."
Jeff S. |
