PIC to PIC communication
ibebev
PostPosted: Fri Oct 22, 2004 9:32 am     Reply with quote
I need to send a 18 bit binary number from one pic to another pic of the same type. I am using PIC16F877A. I was wondering if anyone knew of a way to do that without using the serial port. I don't necessarily need to clocks to be syncronized. Is there a way to just send data out of one output pin and into an input pin on the other pic Question
Thanks for your help,
B Very Happy
PostPosted: Fri Oct 22, 2004 12:29 pm     Reply with quote
There is a method given in the CCS FAQ, though I admit I've never
done this.
http://www.ccsinfo.com/faq/?23
SherpaDoug
PostPosted: Fri Oct 22, 2004 1:51 pm     Reply with quote
One could also look at using SPI or IIC serial transfer. Both are readily available standards with minimal hardware.
arunb
RE
PostPosted: Fri Oct 22, 2004 11:48 pm     Reply with quote
Serial communication may also be used ( in this case you need not use the MAX 232 IC ).
thanks
arun
Dazzle
PostPosted: Mon Oct 25, 2004 2:33 pm     Reply with quote
Nooooo!, have one PIC with speech synthesis and the other with an "electronic" ear.
The transmitter could speak the number in a human voice and the receiver could listen and recognise this.
Laughing
