Sigma
12f629 with i2c eeprom |
Posted: Tue Oct 26, 2004 2:32 am |
Hi, all,
I am now testing a serial eeprom 24aa32 with 12f629 with compiler version 3.178. I use pin_a5 as SDA pin, pin_a4 as SCL pin with 1k resistors pull-up. And also pin_a0 with a 1k pull up resistor to control the WP pin of the eeprom chip. However, the code is not working. Then i emulate the code using icepic emulator of 12C672 (of course with some include statement changed), it is working fine. Is it due to some i/o property problems of 12F629? But i already disable the comparator, and make them all digital i/o in the code. what went wrong? Pls advice.
Sigma
#include "12F629.h"
//#include "12C672.h"
#fuses INTRC,NOWDT,NOPROTECT,NOMCLR,PUT
//#fuses XT,NOWDT,NOPROTECT,NOMCLR,PUT
#use delay (clock=4000000)
#define WP PIN_A0 //GP0: Write Protect for FRAM
#define LED PIN_A1 //GP1: 1: Energised, 0: dis-energised
#define EE_SDA PIN_A4 //GP4: I2C data line
#define EE_SCL PIN_A5 //GP5: I2C clock line
char cmd;
#byte CMCON=0x19
#byte ANSEL=0x9f
* 24AA32 functions - I2C Bus
#use i2c(master, SDA=EE_SDA, SCL=EE_SCL) //I2C bus
void init_i2c(void) { //Init EEPROM
output_float(EE_SCL);
output_float(EE_SDA);
char read_24AA32(long int addr) { //Read 1 byte
char data;
i2c_start();
i2c_write(0xa0);
i2c_write((((0xff00)&addr)>>8));
i2c_write(addr&(0x00ff));
i2c_start();
i2c_write(0xa1);
data=i2c_read(0);
i2c_stop();
return(data);
void write_24AA32(long int addr, char data) //Write 1 byte
output_low(WP);
i2c_start();
i2c_write(0xa0);
i2c_write(data);
i2c_stop();
delay_ms(10);
output_high(WP);
* main
main() {
char i;
short done;
CMCON=0x07; // Comparator off.
ANSEL=0x00; // All i/o digital.
init_i2c(); //Init EEPROM
output_low(LED);
ext_int_edge(h_to_l);
disable_interrupts(GLOBAL);
setup_counters(RTCC_INTERNAL, WDT_1152MS); // The RTCC prescaler is set to 1
// because we are setting the
// WDT prescaler
done=FALSE;
delay_ms(2000);
while (1) {
if(!done){
done=TRUE;
for(i=0;i<254;i++){
write_24AA32(100,i);
cmd=read_24AA32(100);
if(cmd==i) {
output_high(LED);
delay_ms(50);
output_low(LED);
delay_ms(50);
else if(cmd!=i){
output_low(LED);
i++;
} //while (1)
Sigma
Posted: Tue Oct 26, 2004 3:23 am |
It seems like pin_a4 is not functioning in my case. I make the pin_a4 to control one led to blink. But the led is always on. Yet for other pins, the led blinks. I also test the i2c on pin_a0 as scl and pin_a1 as sda, it is working. Anyone know why pin_a4 not functioning as a digital i/o? It seems to me it still in the analog mode.
Sigma |
Will Reeve
Joined: 30 Oct 2003 Posts: 209 Location: Norfolk, England
Posted: Tue Oct 26, 2004 3:41 am |
On a lot of PICs A4 is an open drain output. |
Sigma
Posted: Tue Oct 26, 2004 3:49 am |
Solved. Inside the #fuse statement, modify intrc to intrc_io. Then led can be blinked. and i2c also working. Thanks.
Sigma |
