How to get label address at compile time
Mark M
PostPosted: Sat Sep 25, 2004 7:04 pm     Reply with quote
I am trying to write simple task switching scheme similar to "LeanSlice" by Knudsen Data Norway. I have a following macro:
#define waitState() \
L0?:
#asm ASIS \
movlw L0?%256 \
movwf Lstate \
movf PCLATH,w \
movwf (&Lstate+1) \
return \
#endasm; \
Purpose of this macro is to record program counter at location L0? so that at some point my task scheduler can switch back to the L0? location by doing :
goto_address( Lstate );
I am using PCM 3.206
Any hints?
Mark M
Mark M
reading label address at compile time
PostPosted: Sat Sep 25, 2004 7:11 pm     Reply with quote
I just realized that the code may have to be modified because PCLATH is not readable. It would have to be something like that:
L0?:
#asm ASIS \
movlw L0?%256 \
movwf Lstate \
movlw L0?/256,w \
movwf (&Lstate+1) \
return \
#endasm; \
Any hints?
Mark M
drh
PostPosted: Sun Sep 26, 2004 10:03 am     Reply with quote
See page 109 and 110 of the July, 2003 reference manual for
label_address() and goto_address().
David
Mark M
How to ge label address at compile time
PostPosted: Mon Sep 27, 2004 10:30 am     Reply with quote
David,
For what I want to do ( task switching in rtos ) those directives, and particularly goto_address produces a BIG chunk of code with many redundant instructions.
I acutally found a way to do it in CCS. You have to define a function as #inline instead using macro. In that case preprocessor expands function first and assigns a different address to every occurence of the same label. There is only one "but". It produces 2 redundant instructions as inthe example below:
CCS PCM C Compiler, Version 3.206, 24834 27-Sep-04 10:19
.................... int16 p;
.................... Label1:
.................... p =label_address( Label1 );
008C: MOVLW 00
008D: MOVWF 7A <-- redundant, this is @SCRATCH, what is this for ??
008E: MOVLW 8C
008F: MOVWF 62 <-- this is &p
0090: MOVF 7A,W <-- redundant
0091: MOVWF 63 <-- this is &p+1
it would be more efficient to do it as:
008C: MOVLW 00
008D: MOVWF 7A <-- this is @SCRATCH, what is this for ??
008E: MOVWF 63 <-- this is &p+1
008F: MOVLW 8C
008A: MOVWF 62 <-- this is &p
or even this:
008D: MOVLW 00
008F: MOVLW 8C
but how to do this in C or better in assembly ??
I only wish the PCM programmer or Darren would look at my post ...
Mark M.
PostPosted: Mon Sep 27, 2004 10:56 am     Reply with quote
Well, how about Mark looking at your post ?
This sounds like it's right up his alley. Mr. Green
Mark
PostPosted: Wed Sep 29, 2004 6:08 pm     Reply with quote
How do you plan on handling local variables? Are you planning on making them all "static"? What does your task handler look like?
Mark M
rtos thing
PostPosted: Thu Sep 30, 2004 9:42 am     Reply with quote
Local variables would have to be protected, so software stack for them is one way of solving this problem. Another way, as you suggested is to use only global variables ( or local ones defined as static ).
As to the scheduler, I am still working on details. The most important thing is that this system has to work with PIC16, and possibly with lower as well. As I see it now, the scheduler can be implemented in two ways.
#1:
Scheduler works as inline code part of main():
void main() {
scheduler:
do some arbitration between tasks availabl;
determine task to run (ttr);
load ttr address from task table ( this one is in RAM) into (int16) Lstate
load it into pch and pcl; //this should produce a jump to code pointed by Lstate
// returning from task, Lstate has a new jump point for this task ( this is cooperative multitasking, task has to give up control volunteerly ). Return is dove via "goto sch_1"
sch1:
store Lstate into the task table;
goto scheduler;
This way NO stack is used.
#2. Another way is to use 1 call stack as follows:
vaid main() {
while(1) {
call scheduler;
sch1: // this is where task returns
on returning from task, Lstate has a new jump point for this
Return is done via "retlw".
W can hold extra information about runnung task
void scheduler() {
do some arbitration between tasks available;
(int16) Lstate into pch and pcl;
This should produce a jump to code pointed by Lstate
I guess at this point a call with function pointer as argument
if function pointers can be implemented easily
- but they can not on PIC16
return; /* this will never be executed since task returns
to sch_1: via call stack */
void task() {
wait(); /* this is my inline function with stuff described
as in my original post */
code...
wait();
etc.
I know the code generated will not be VERY compact, but every task will be coded as a distinct function and will be very easy to follow and maintain. Of course you have all rtos gadgets like messages, semaphores, waits etc.
This is in a nut shell. What do you think?
Regards
Mark M
Mark M
PostPosted: Fri Oct 01, 2004 6:38 pm     Reply with quote
It is silly to reply to your own post but I thought I wanted to share this info with you. THERE IS A WAY to get label address at compile time. IT IS VERY simple, once you know it and after reading the manual ! Here is how it is done:
.................... #asm ASIS \
.................... L0: movplw L0 \
000D: MOVLW 0D
.................... movwf Lstate \
000E: MOVWF 70
.................... movphw L0 \
000F: MOVLW 00
.................... movwf &Lstate+1 \
0010: MOVWF 71
.................... return \
0011: RETURN
.................... #endasm
CCS assembler has 2 non-MPASM instructions. Very Happy
ThadSmith
PostPosted: Thu Oct 07, 2004 7:48 pm     Reply with quote
Thanks, Mark. That's exactly what I was trying to do. The follow-up is appreciated! It's pretty hard to find in the manual, especially with no description.
Thad
Mark M.
rtos
PostPosted: Thu Oct 21, 2004 11:35 pm     Reply with quote
I thought I share it with everybody. My rtos written in CCS compiler works ok. Thanks to B.Knudsen Data Norway, another C compiler publisher for inspiration and code samples.
Mark M.
