problems with Capture mode
saroch
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Fri Oct 22, 2004 10:02 am     Reply with quote
here is my code
#include <16F877.h>
#fuses HS, NOLVP, NOWDT, NOPROTECT
#use delay (clock=20000000)
#define use_portb_lcd
#include <lcd.c>
int16 time;
#INT_CCP1
void compare_isr()
   time = get_timer1();
   printf(lcd_putc, "\fCompare Set Int.");
   printf(lcd_putc, "\nTimer1: %lu us", time);
   disable_interrupts(GLOBAL);
   disable_interrupts(INT_CCP1);
   lcd_init();
   setup_ccp1(CCP_COMPARE_INT);
   setup_timer_1(T1_INTERNAL);
   enable_interrupts(INT_CCP1);
   set_timer1(0);
   CCP_1 = 500;      // 500 = (100*10e-6) * (20e6 / 4)
and the output is
Compare Set Int.
Timer1: 538 us
but sometimes the output is
Compare Set Int.
Timer1: 37 us
or
Compare Set Int.
Timer1: 40 us
I don't why it is
the questions are
1. why are the output diffrent?
2. how do these numbers 538, 37, 40 come?
3. CCP_1 = 500; // 500 = (100*10e-6) * (20e6 / 4) means?
thank you in advance
Saroch
PostPosted: Fri Oct 22, 2004 12:54 pm     Reply with quote
I assume this is some sort of a test program for the CCP compare mode.
There are quite a few comments to make, but I'll skip those and comment
on what is probably causing the problem:
lcd_init();
enable_interrupts(GLOBAL); // This line says "Go ! (start running) "
But in the lines below, after you've enabled interrupts,
you're still setting up parameters. These should all have
been setup before you gave the "Go" command.
set_timer1(0);
