printf int32
printf int32
printf int32
PostPosted: Tue Oct 19, 2004 3:38 pm     Reply with quote
I was Looking through the CCS compiler manual and I can't find the printf format for printing a 32 bit number, int32.
is it possible to print a int32?
int32 test;
void test()
test++;
printf("%what\n\r,test);
Also, any ideas on saving the 32-bit number to e2 rom.
Thanks!!
-A troubled software engineer
Mark
PostPosted: Tue Oct 19, 2004 4:38 pm     Reply with quote
Outputs a string of characters to either the standard RS-232 pins (first two forms) or to a specified function. Formatting is in accordance with the string argument. When variables are used this string must be a constant. The % character is used within the string to indicate a variable value is to be formatted and output. Longs in the printf may be 16 or 32 bit. A %% will output a single %. Formatting rules for the % follows.
See this post for a bug with int32
http://www.ccsinfo.com/forum/viewtopic.php?t=20746
