Macro question
alexz
Macro question
PostPosted: Fri Oct 22, 2004 3:31 am     Reply with quote
How can I create a macro for reading a port?
Alex
alexz
PostPosted: Fri Oct 22, 2004 3:37 am     Reply with quote
Also the input/output port/bit functions do not work in my compiler V3.190
for some reason.
Alex
alexz
PostPosted: Fri Oct 22, 2004 3:44 am     Reply with quote
In other words, how can I make a macro instead of this function?
BYTE ReadUSBNbus(void)
USBN_BUS_DIR = INPUT ; //TRISC = 0xFF
return(USBN_BUS) ; //read PORTC
DataByte = ReadUSBNbus();
Alex
PostPosted: Fri Oct 22, 2004 3:51 am     Reply with quote
I don't know, but I'm curious why you'd want a macro for that, instead of a normal function Question
alexz
PostPosted: Fri Oct 22, 2004 3:56 am     Reply with quote
The reason for that is all the similar stuff in the program is defined as macro, I would like to keep the same standard
Alex
dvsoft
PostPosted: Fri Oct 22, 2004 4:38 am     Reply with quote
bonjour,
Function
Macro
#define ReadUSBbus(BUS)\
    USBN_BUS_DIR = INPUT ;\
    BUS = USBN_BUS
Usage
    byte X;
    ReadUSBBus(X);
Alain
dvsoft
PostPosted: Fri Oct 22, 2004 4:41 am     Reply with quote
Re,
but with compiler CCS you can use
#inline
look at the code assembler which is produced
Alain
alexz
PostPosted: Fri Oct 22, 2004 4:43 am     Reply with quote
dvsoft wrote:
bonjour,
Function
Macro
    BUS = USBN_BUS
Usage
    byte X;
    ReadUSBBus(X);
Alain
So where do you read the port to?
Is the 'BUS' returned from macro writing it this way 'BUS = USBN_BUS' ?
If it does return, so to where?
Alex
PostPosted: Fri Oct 22, 2004 5:45 am     Reply with quote
alexz wrote:
dvsoft wrote:
bonjour,
Function
Macro
    BUS = USBN_BUS
Usage
    byte X;
    ReadUSBBus(X);
Alain
In the example given, he shows a byte variable, called 'X' being declared, and then the macro being used, with this variable passed as it's argument. The macro declaration itself, shows it's argument given a name 'bus' (any suitable name can be used here). The macro 'expansion', then substitutes the passed variable (in this case 'X', for every location where the argument is used.
So the macro expands as:
    USBN_BUS_DIR = INPUT;
    X=USBN_BUS;
The ';' on the end of the line, gets added to the end of the macro, making the line complete (in C terms).
If you called the macro with:
    byte X,Y;
    ReadUSBBus(X);
    ReadUSBBus(Y);
The expansion would be:
    X=USBN_BUS;
    Y=USBN_BUS;
You can also do things with macros, that are often 'missed' by a lot of C programmers. For instance:
#define ReadUSBbus() (USBN_BUS_DIR = INPUT,\
    USBN_BUS)
Used like this:
    Byte X;
    X=ReadUSBbus();
Creates a macro, that behaves more like a function, returning a value!. What happens, is that the seperate parts inside the round brackets (seperated by ',', rather than the normal C terminator of a ';'), are executed in turn, and the value of the last statement, is 'returned'. Hence in this case, the value of 'USBN_BUS', gets returned. This behaves exactly like the function in your original code, except that it is automatically 'inline'.
alexz
PostPosted: Fri Oct 22, 2004 6:49 am     Reply with quote
Thank you very much!
It really helped!
Alex
